#26
Here are the recommendations from BMW on M car oil: BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles equipped with S54, S62, S65 or S85 engines: Castrol TWS Motorsport SAE 10W-60 Synthetic Engine Oil Castrol Formula RS SAE 10W-60 Synthetic Engine Oil (BMW part number 07 51 0 009 420) If Castrol High Performance Synthetic Oil is not available and you need to add oil between oil changes, only use synthetic oils with the following specifications for M vehicles: Viscosity - preferred SAE 10W-60 Alternative - SAE 10W-40, SAE 5W-50 or SAE 10W-50
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar. |
#27
Stick with ANY good name brand synthetic and you'll be good. I've never noticed a difference in any oil I've used...chances are the rest of the car is going to fall apart before a BMW motor fails internally from wear. I run Lubro-Moly right now, but for the majority of my vehicle's life (181,000 miles) it has run Castrol. Newer oils have excellent detergency and breakdown resistance, so I wouldn't hesitate to go with most any synthetic.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
