Old 05-21-2012, 03:17 PM
junefelix junefelix is offline
Mein Auto: 2004 bmx x3
key will not turn, steering wheel locked
The key will not turn in the ignition, tried the extra key and it worked once, now neither key will turn and the steering wheel is locked, what could it be? 2004 X3
Old 05-21-2012, 03:52 PM
chagrin chagrin is offline
Mein Auto: M3/X3/XI
Make sure it is in park and your foot is on the brake; if the steering wheel is still locked, pull firmly to one side or the other.
Old 05-21-2012, 06:51 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Jiggle wheel a bit side to side as well. Sometimes it will lock against the torque.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 05-22-2012, 07:38 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
+1, you might have to "jiggle" the wheel with a fair amount of force -- back and forth -- to get it to unlock. Don't give up.
Old 05-22-2012, 11:21 AM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
TRy this
If your front wheels are turned significantly one way or the other they may be putting a lot of pressure on the steering apparatus thus not allowing the key lock to release. If this is the case you might try jacking the front end up to release the tension and see if the lock will release then. I had a family member with a Cherokee that parked with his wheels in full lock position and as soon as the wrecker started dragging him up on the rollback they lock released and he was good to go.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 05-25-2012, 05:36 PM
MADBMWX1 MADBMWX1 is offline
Mein Auto: 2013 BMW X1
Yes, frustrating. You will feel as if you are going to break something, but follow the advise above and you will be OK.
Old 05-26-2012, 02:08 PM
Proud Highway Proud Highway is offline
Mein Auto: 2009 X5 3.0; 2006 X3 3.0
Mine had this problem too. Upon closer examination I noticed the grooves in my key were really dirty. I cleaned the key with 409 and an old tooth brush and some plastic pics I use to clean firearms. I also took the vacuum to the ignition with a little detail nozzle just in case there was some transferred pocket lint that could be dislodged.
The ignition has not stuck since.
