Old 06-14-2012, 06:00 PM
supakilla813 supakilla813 is offline
Mein Auto: bmw 650i
call your dealer for the battery cable recall. give them your vin and they will tell you what recalls your car has. our cars have lots of recalls they replaced my positive terminal cable to my bme for free
http://consumerguideauto.howstuffwor...6-series-9.htm
i love my bme 650i
Old 08-25-2013, 06:36 PM
Bestbimmer Bestbimmer is offline
Mein Auto: 650i 2007
Originally Posted by blaze_500 View Post
So... i noticed a message on the iDrive - "increased battery discharge".
Ive charged the battery on a slow charge for 2 days. The charger indicates the battery is charged, i try to start the car. exactly the same issue no difference at all.
I'm thinking a few options now.
Perhaps my battery is screwed and needs replacing.
Battery is fine but a sensor somewhere is faulty telling the car it has charge issues
Something is draining the battery.
The fact this happened within a few hour of the car being absolutely fine still baffles me.
Any ideas guys?
Much appreciated.
Having same problem car won't start but I hv a new battery
Old 08-26-2013, 02:59 PM
RooK77 RooK77 is offline
Mein Auto: 645i
Originally Posted by Yorgi View Post
You cannot repeatedly start the car without charging the battery or it will run down very quickly. Starting the car is a MASSIVE drain on the battery.
Hello Yorgi, are you certain that the battery is drained that much when the engine starts? In other thread I read that if that would be so the new "start/stop" systems used in modern bimmers would be pointless.
Old 08-27-2013, 03:55 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Most engines require 300-600 amps during startup. To give you an idea of the magnitude - 600A at 12V is more than half the power you can get out of an entire house fuse panel (100A at 120V) Note how thick a battery cable is.
I have not looked into what BMW and others are doing to handle the issue of battery drain on these automatic start/stop systems. I would guess they are either installing massive batteries, very large alternators for faster recharging, or have developed super efficient starters that require less current compared to what was normally used. I could also see them using big capacitors to help with starting.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 08-27-2013, 04:18 PM
Mein Auto: 645i
Wow... that is a lot of power.
Modern BMWs are using brake energy regeneration systems (see this image).
Not sure about other manufacturers.
