E34 (1989 - 1995)
Old 05-23-2012, 04:10 AM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
Removal of Tie Rods
There's a 94 530 at a junk yard near where I live and it has (as far as I can tell) brand new tie rods. The man wants $100 for them both along with the centre main tie rod thing. How can I remove them? Is it just a matter of un-screwing it? Advice is greatly appreciated.
Old 05-23-2012, 06:03 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
I just bought all four rod ends for $70, I am not sure I would spend more than that for unknown junkyard parts.
The tie rods are easy enough to remove, the center link needs to be disconnected from the pitman and idler arms before it can be removed. The easy way is the good ole pickle fork... hammer it in between the parts and it separates them. Problem is, unless you are very careful you can damage the rubber grease boots and joints.
Depending on the amount of corrosion underneath, often you can get lucky and remove them but backing off the nut until it is above flush with the bolt then hitting it with a hammer, being careful not to damage threads.
The biggest problem with removal and re-use is that they were really designed to be discarded, not re-used. You should be able to pull it off though if you are careful.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 05-23-2012, 06:13 AM
injunmort injunmort is offline
Mein Auto: 1990 525, 1991 535
you can get new for less without the hassle of removal. try fcp groton.
Old 05-23-2012, 07:31 AM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
I agree on that one. Tie rod assemblies are not that expensive. Buy new if you can. If you are going to get them from a junk yard, they should not be hammered out as you will be reinstalling them in your car.
I feel that it is worth the 30 bucks to get the correct tool. There is a good chance that they will not get damaged but why risk it, Especially if you have not removed tie rods before.
Mine came from bavauto, EcsTuning also sells them.
It was worth it for me to buy one as I have used it relitively often but situations may varry
Old 05-23-2012, 12:39 PM
Costa's Avatar
Well I need to replace one whole tie rod like both ends and middle part because it seized somehow. I'll probably just pay the extra money and get something brand new. I just hate buying things online because they come 2-3 weeks after you purchase, I guess I'm just too impatient.
Old 05-23-2012, 03:38 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Hi Costa , +1 on The tool Trevor showed and also +1 on snowsled's advise on new parts ... Patience is a virtue says Bruce Lee or Bruce Lie one of those Bruces lol not sure which one ... It's the Bruce that kicked Chuck Norris ass lol
Sent from my Desire HD using Bimmer App
Old 05-24-2012, 10:47 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
Too much $ for those, let him crush them. Buy new for not much more, if that. Er, center link is a bit $ @ ~ $100
Take my advice, I'm not using it.
Old 05-24-2012, 12:27 PM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
Lol. Do not get any parts made by FCP Groton
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
