X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
2011 E70 Computer Mods?
This is a repost from my "New Member Introductions" post yesterday:
---------- Hello All, Just joined the forum, and am in desparate need of advice. I own a 2011 X5 x35i Sport Activity which I use as a regular driver (~15000 miles/year). This is my first BMW, and I'm sorry to say I've been pretty disappointed with it. Once it's rolling, it's plenty fun to drive, but two major design flaws usually have me red-in-the-face mad before I ever get to that point. First, the accelleration lag is the worst of any vehicle I've ever experienced. The delay between hitting the gas and being pushed into the seat is on the order of two seconds. I seriously have to plan my accellerations in advance just to enter traffic. The second is the rediculous safety systems. There are numerous situtations where the computer will reject my request to put the vehicle in gear. Some of this is mandated, but most are at the discretion of BMW designers. For the "ultimate driving machine," I would expect more emphasis on the driver. So my question is this: are there any E70 modifications out there that will solve these problems? I can live with the safety systems, but the accelleration lag will have me selling the vehicle soon if I can't find improvement. Thanks in advance for your input, Phil |
I feel you on the 2 second delay. I hated that also. There is a cure for that....its rather expensive though. I did it on my X5, but not for the 2 second throttle response delay you speak of. I did it cause I wanted more horse power. The benifit to that was crisper throttle response. Now as soon as i touch the pedal, the truck takes off.....you know, like normal cars. This is how it should have been in the first place. The mod im speaking of is the Dinan stage 2 software package for your vehicle which costs upwards of $2,200. Im telling you about this solution cause it worked for me. There is a less expensive solution, but im not familar with it. Maybe someone else can chime in and help. Its called the Sprint Booster throttle enhancer. It sells for around $300 I cant remember now, but I saw a place that was selling it with a 30 day free trial and free shipping. A newer version even has a sensitivity adjustable switch. You can probably google it. Whatever you do....keep me informed and let me know which way you go on this. Im curious to know the outcome.
Regarding Sprint Booster I've had it and returned it on my E60. As I have said before on another forum..
Read the attached in depth, but the short of it is that the Sprint Booster is a little amplifier, nothing more. It increases the signal from the pedal box by about 30%, meaning that the ECU thinks you're pressing the pedal about 30% harder than you really are. You're effectively using a megaphone to make your will known to the committee. This would definitely make the throttle feel more responsive since you're making a smaller amount of right hoof count for more, but know this: For $300 you get: * A pedal that feels more responsive because the gain has been turned up, * A pedal where the top third of the range of motion doesn't do anything since you've multiplied the signal by 30% and max it out by 2/3 throttle, * And, the kicker, the same thing you would have gotten if you pressed the pedal a bit harder.
2013 X5 35i Premium, Space Gray, Cinnamon Brown Leather, Dark Bamboo wood trim, Conv. Pkg, CWP, Multi-contour seats, Running board, BMW App. Space saver tire. 2010 535i - Deep Sea Blue w/ NBD Leather, Bamboo Anthracite WT, Sport Auto Trans w/ Paddle shifter, Sports Pkg, PP, CWP, Nav, HD Radio, Ipod. - Returned 2007 525i - Black Sapphire Metallic, Black Nevada Leather, Premium package, CWP, 6MT. - Returned |
I'd look at the Dinan, the other thing you could do is check with the dealer to see if their are any newer DME updates for your X5. There's been issues with the N55 flashes that pretty much kill the throttle response.
09 135i 6MT, ZMP, PPK1 13 X5 35i ZMP, ZMX, 2VA 13 Tiguan SEL 4motion |
Sounds like there is something wrong with your car.
I've never heard of a car not shifting into gear for 'safety reasons'...did your (lying, make up crap because they are stupid and lazy) dealer tell you this? Make them put your complains in writing ON THE WORK ORDER, **AND** make them write out their weak explanations in the repair document...THEN go to BMW. If they were to write 'car does not shift into drive due to safey' or 'Two second lag is normal", you'd have something to press with BMW. I'll bet their responses are of the "operates normally at this time' and 'cannot replicate'.... I would FIRST make sure it is functioning properly before modifying it and eliminating any dealer help forever.
Keep it as simple as possible...but no simpler. |
I'd heard of Dinan before, but last I checked they hadn't developed the mod yet for the x35i. I'll give it another look in case that's changed. As to the safety systems, try backing up with the door cracked open and your seat belt off. The vehicle will actually start moving in reverse, and then kindly shift into park and clamp your head in the door. I have a similar story dropping a fast food order between the driver's door and the drive-through window. Try to imagine the looks on the faces in my rear-view mirror as I inched ther vehicle back & forth a couple times trying to zero-in on the food location with the door closed!
But the gears will shift unless rpms are too low or too high for that particular ratio. So I am not sure what is going on, press them to fix it, and as many people suggest - make sure to document the issue and the responses in writing, always. With such an expensive toy you have to be a bit of a lawyer to protect your, hmm, "investment". Good luck!
2013 BMW X5 35i Sport Activity SAV, 19", Space Gray, Black Leather, Dark Wood, Convenience, Cold Weather, NAV, BMW Apps, Running Boards, BMW Crossbars, BMW Tow Hook Bike Carrier |
I've not experienced this on my previous BMW turbo car as well but I have read other owners having this issue.
My year of the x35i was the first with the high-output 6 cylinder (taughted to be as fast as the previous year's V8) and 8-speed transmission. It wouldn't surprise me, therefore, if they still needed to work out the kinks in the control system, and summarily fixed it in a latter edition. I'll take your advice and talk to the dealer first about a software update. If that doesn't work, then it's off to Dinan for a mod. Thanks, Everyone, for the brilliant feedback! Now if I can only get my throttle to be as responsive... ;-)
FYI-
I seem to recall reading that BMWNA may have an internal SB with dealers that requires them to 'turn away' customers multiple times before they will take serious (ie expensive) actions. A
Would you consider trading the 35 for a 50? That may be the hp/torque/speedy feeling you are truly looking for ( if money is no option, of course). Few thousand dollars difference once you consider the cost of the Dinan.
2011 X5 SAV titanium silver/black/aluminum 2013 Subaru Impreza graphite gray/black replaced the 335 ![]() RIP 335i xdrive DSB/gray ![]() RIP 2005 Subaru Legacy GT RIP 1986 Honda Accord (involved in three car accident while pahked in the North End) RIP 2002 Mini Cooper (90th produced) |
For example if your door is open, the computer not let you shift from P to D; if you're in D and rolling less than 5 mph or something and you open the door, the computer will shift to P which very likely to damage the transmission; etc.
2013 Range Rover S/C 2009 X5 48i - Sold |
I recently bought an '08 3.0si and I have the exact same 2 second delay your talking about. I'll ask the dealer as well. it still has one year of CPO left on it.
They took my key, inserted it to a device, and after a minute or so told me the car was current on everything. It's going in for an iPod dock though and they are going to look at my complaint.
I've seen this Dinan software mod, but can you do it yourself? What's involved? It's looks like software that you need to install onto a laptop, then communicate with your vehicle? But it does work in your opinion? Does it void any warranties? |
Only if BMW finds out. And despite what ANYONE says, they can.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
