Old 05-23-2012, 03:10 PM
michaelthomson1 michaelthomson1 is offline
Mein Auto: Bmw 740i
Mirror glass replacement
how do you change the mirror glass on the e38, the mirror is auto dim
Old 05-24-2012, 06:11 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
The mirror glass is symetrical, so the same may be used on both sides, although different galsses are available. Tilt a glass to face upward,and look into the gap between the glass and its housing. You should be able to see a black plastic spike pointing straight down, in the middle. If not, tilt the mirror down and repeat.
Press the spike with a screwdriver to one side, which rotates a ring on the back of the glass, in turn releasing the glass assembly. Take it easy-you don't want to break the spike off-if it doesn't move with moderate pressure, try the other direction. It only moves a few mm
The spike on the other side of the car may be in the opposite position.
HTML code is Off
