E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
99 ///M Rdstr trunkfloor repair...
I took the car in yesterday and met with the body mechanic this morning. He wanted to know what I wanted done, so the Service Manager asked me to meet with him.
BMWNA's suggestion to replace the entire trunkfloor panel made me a little nervous. If they had devised an entire new assembly that addressed the weakness of the original, that would be a different story... Cutting an otherwise good car in (nearly) half to wind up with a car that was no stronger than it left the factory five years ago does not seem like the right solution to me. I don't want to repeat this again, not with the same car anyway! I will be repeating the process again with the other car as soon as this one is done and passes judgement. It has been determined to not section in the entire assembly, but to repair the (albeit minor) damage and strenghten the area using the pieces laying in the trunk. Picture me taking a big sigh of relief! Those pieces laying in the trunk will be utilized to strengthen the xmbr as described here Here are a few pictures that show how big the Z3's trunk is when it's not in the car.
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon Last edited by Randy Forbes; 06-11-2004 at 02:43 PM. |
I echo the big sigh of relief!
Tht did NOT sound like a good way to fix things.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
Not much to report for the past week (judging by the activity of this thread, not likely a problem
).I stopped by yesterday and the car is "almost" apart; all the trunk trim has been removed and the bumper and tailights were also removed to save them from damage while the work takes place. They still have to drop the subframe, not so much for their repair operation, but as a favor for me to be able to pull out the old subframe bushings and replace them with the Ireland ones. You've got to love that kind of cooperation They also discovered that the differential mounting ear was starting to crack (remember that this car was only autocrossed just a handful of times and never by Sue). Just a couple shots that show the naked trunk before work commences.
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
Randy,
Is BMWNA covering the cost? Who is doing the work? Nice Healey! Did you go to the annual British car show at Easton?
Randy
Your email must have problems, BMW NA forwarded this to be to get it to you Dear Randy Forbes: I am Edward Longshanks with bmwna, We have figured out that the use of your hardtop is possibly the cause of your sub frame problem, I am pleased to let you know that a remedy had been found. It was staring us all in the face the whole time. All that is needed to be done to keep this from happening again is to ship your hardtop to san antonio and we will take it from there. thank you for your time and safe driving E. Longshanks Senior Director of Lets get Max a Hardtop
I am right I saying no pieces of the trunk floor section BMW sent are being used in the repair?
Only the pieces you devised.
2000 Imola Red M Coupe Dinan suspension, M rotors /Axxis pads Eurosport Cam Kit 1, touch lane change Zaino polish, Beach Sand Garys mirror adapter, S54 Oil Cooler seat tilt coupling nuts, spare tire "life's to short to drink cheap beer"
shouldn't we be looking at adding this also?
Who was it that welded on a second ear to the diff housing? He had the black coupe at the fix it day.
2001 Alpine / Schwartz Coupe 2001 Estoril / Estoril Coupe 2001 Steel Grey / Estoril Coupe 1999 Estoril / Estoril Coupe Sunroofs are for girls. |
I can give you more details at HC...
Randy,
YOU ARE AMAZING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Respectfully,
D! 87 325is Track Project 2004.5 Jetta GLI 1.8T FOR SALE! Hunting for a healthy E36 M3 My Ex-es: 2000 Cosmos M Coupe 2003 WRX 1998 328i ... and many more! |
Bodyshop manager called me up yesterday evening and said I should come by for a "Kodak moment".
Armed with a box of fresh donuts, I showed up first thing this morning to get a few more shots of the progress.
Stopped back by again this afternoon to see how things went and got a couple more pictures.
These pictures show the differential mounting ear that was modified by overlaying a second stamping on top of the original to double the wall thickness. The tech was proud of the fact that you have to really look close to see the difference. When the job is finished, it's important to him that it looks "factory". My kind of guy!
Looks nice so far.
I talked to Ireland Engineering about moving the trailing arm mounting plates on this crossmember to adjust the camber so I dont go through tires so fast... Has anyone thought about this?
![]() I'm curious to hear a description of the access and removal process. This reminds me of Boyd Coddington's shop on American Hot Rod (Discovery Channel, Friday nights). Fortunately for you, Bluebear is not lurking in the corner shooting paintballs at the other shop employees.
Stay tuned for continued coverage...
A little more progress to report. Monday he'll probably get the pieces that I made up welded in place. Right now, his biggest concern is finding the correct shade of seam sealer and "E-coat" that was put on at the factory.
These pictures show the flat plate that was welded inside to the bottom of the xmbr. The vertical membrane will be welded to this plate and the cap (via plugwelds).
so you cut out the cross member to add INSIDE the hollow an additional plate.
The xmbr wasn't cut, the floor section above it was cut out to get access to the inside of the xmbr. He still has the vertical membrane to install and then he'll finish it off with the piece I made. See below:
Only needs to be put back together now. They'll work on other jobs while I continue to wait on the Ireland bushings (called them again today...).
#25
Looks good, and a lot stronger than what was (not) there from the factory.
Daniel 2002 M roadster |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
