Old 05-25-2012, 12:32 PM
CJ645Bern's Avatar
CJ645Bern CJ645Bern is offline
youtube.com/lidlgangsta
Mein Auto: 05' 645ci & 01' z3
Z3 a bit of traction control with traction control off?
2001 z3 3.0 5 spd man. tried doing a search but couldnt find anything. love the car but i wanna enjoy it even more. im a teenager so i do typical stupid things other teens would do. but even with traction control off, i still cant "skid/drift". with t/c off, its still like the traction is being controled. for example, i tried turning hard off turns to make the wheels spin, but i cant. and no its not my driving lol. i know its dumb, but with this going on, you cant do donuts or burnouts (i probably wouldnt do it anyway, im just saying how restricted it is even with t/c off) so in other words, i wanna enjoy it as much as i can with the 6. with the t/c off in the 6, i have no trouble spinning my tires.
live fast, drive faster
2010 Acura TL (daily driver)
2005 BMW 645ci Coupe (traded for TL)
2001 BMW z3 3.0i vert' (TOTALED RIP)
1991 NISSAN 300zx 2+2 (gave to brother)
2007 BMW z4 (traded for 6er)
Old 05-25-2012, 03:08 PM
dkindig dkindig is offline
Mein Auto: '01 Z3 3.0i Roadster
With DSC turned off I have had no trouble at all getting completely sideways and powering through the drift while turning from a dead stop. Same car, '01 3.0...
With that being said, don't drive like that. The DSC will save your a$$. I started with MG roadsters in 1977, and I am completely comfortable driving a tail-happy car and controlling its direction and angle with throttle inputs. If you want to keep your car I would recommend leaving the DSC ON.
The stability control on these cars is very capable and non-intrusive. I haven't driven mine at 10 10ths, but at 8-9 10ths the DSC has been very workable. It has never killed the power output, just braked as needed to prevent getting out of control. The ONLY time I have experienced the electronics cutting power has been when I have bounced off the redline hard.
Old 05-25-2012, 03:23 PM
CJ645Bern's Avatar
Its true I shouldnt drive like that but I'm still confused as to why I still can't get sideways. Like my 6, theres two levels of dsc. Ones like half off and the others completely off. Would that be the case for the z3?
Sent from my HTC Glacier using Bimmer App
Old 05-25-2012, 03:46 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Don't forget that you also have a limited-slip differential. That helps to keep the back under control as well.
Old 05-25-2012, 04:05 PM
CJ645Bern's Avatar
True but I wanna know why dkindig (above) can go sideways but I cant if we pretty much have the same exact car.
Old 05-25-2012, 05:40 PM
http://www.bimmerfest.com/forums/showthread.php?t=54522
All the info you need is in that post. The real determining factor is the manufacture date of your car. My car has the Teves Mk 20 system, therefore is only capable of on and off via a quick press of the button, or being sent into error mode (essentially off) with a long press greater than 10 sec.
The other thing is that you might have it switched off but you're not pushing the car hard enough to break it loose. If the DSC is still on, you should see the warning light flash when it's doing its thing.
Old 05-27-2012, 07:00 PM
CJ645Bern's Avatar
I figured it out guys. Just like my 6, I just have to hold the t/c button and its completely off. Thought I tried this before but I guess not. Thanks for the replies!
Old 05-29-2012, 06:20 AM
GA Z4 GA Z4 is offline
Mein Auto: 2004 Z4
Next post: Parting out my 01 Z3!
Old 05-29-2012, 06:28 AM
CJ645Bern's Avatar
Lmao! No I'll be fine haha
Old 05-29-2012, 12:38 PM
Benjamin757 Benjamin757 is offline
M52B28
Mein Auto: 1998 BMW Z3 2.8
Exclamation
Bern seeing that you are a teenager... drifting comes with experience. You also have to power into the turn not just turn with throttle. if you want the back end to go out you have to yank the wheel the way your turning with a lot of throttle then control the slide by turning back the other way. You need to practice away from traffic or not at all.
Old 05-29-2012, 12:40 PM
M52B28
Also these older z3s are prone for the rear subframe to break from driving like that.
Old 05-29-2012, 01:49 PM
CJ645Bern's Avatar
true benjamin. im careful with my driving. yes, every teenager says they are a good driver, but im sure im mature and good enough to say that i am. but what do u mean its prone for the subfrrame to break?
Old 05-29-2012, 04:55 PM
CJ645Bern's Avatar
also i didnt really mean to say that i wanted to drift. all i would like to do it get sideways
Old 05-30-2012, 05:11 AM
M52B28
http://i248.photobucket.com/albums/g...r/IMG_0640.jpg
http://www.turnermotorsport.com/imag...subframe_2.jpg
http://www.turnermotorsport.com/imag...6sf_011306.jpg
If you don't power out of the corners smoothly these is most likely what will happen and is a very difficult fix, trust me a lot of welding and bloody knuckles!
What would you attempt
if you knew you
could not
fail?
Old 05-31-2012, 08:38 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
I teach high performance driving at a track. I hear that all the time from young drivers and even older and old drivers.
It is RARELY true. Until you spend some time getting some serious driver training and/or do something like autocross to learn how to drive consistantly at the limit, you are NOT that good of a driver.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 05-31-2012, 08:47 AM
CJ645Bern's Avatar
Ill take ur word. im done driving like that for awhie yesterdya. Just got a ticket so ill use that as a lesson lol
Old 05-31-2012, 09:19 AM
ghpup's Avatar
ghpup ghpup is offline
Glfbggy
Mein Auto: 07 X3si, 14 535xd, 00 MZ3
Bern, make sure you review those links for the subframe failure issues. I do not drive that agressively so I don't necessarily have concerns. When I do drive 'spiritedly' I leave the traction control active to, as another poster indicated, save my backside. I got the tail out once without much effort. This vehicle cost too much for me to treat as a disposable posession.
GLFBGGY
'00 MRoadster, '00 528 now in other hands, '07X3si, '14 535d XDrive
Old 05-31-2012, 09:33 AM
CJ645Bern's Avatar
Yahhh that's very true. But my ticket from last night will prevent me from driving sfupid for now anyway. Thanks
Old 06-01-2012, 07:43 AM
Pinecone's Avatar
M Mad
AFAIK there is no evidence that spirited driving has anything to do with rear trank floor failures. Same for engien size, some 1.9L cars have had the problem.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 06-01-2012, 02:04 PM
Randy Forbes's Avatar
Investigative Tinkerer
Z3 Series trunkfloor/differential mount failure. Here's a few pictures of a car I'm working on right now...
I'm off to a slow start on repairing this car, as I just moved (4/27/2012) and I'm still unpacking and trying to get organized at the same time. Today, I've been doing a bunch of secondary operations trying to get some trunkfloor/differential mount reinforcement packages ready to ship out.
This is what will repair this car and prevent it from happening again.
Want to see more? Check out www.spcarsplus.com/gallery3
Randy Forbes
2001///M Rdstr Steel Gray
Old 06-02-2012, 09:26 AM
CJ645Bern's Avatar
1.doesnt look easy
2.doesnt look cheap
3.something a teenager like me doesnt wanna deal with
4.lets not touch that t/c button haha
Old 06-02-2012, 12:04 PM
1.doesnt look easy
2.doesnt look cheap
Very astute!
Randy Forbes
Old 06-04-2012, 05:32 AM
M52B28
Thumbs up
I'm glad you agree Randy! Took two weeks to fix mine (like 2 hours a day)
if you knew you
could not
fail?
