E34 (1989 - 1995)
Old 05-27-2012, 10:37 AM
NAVYMAN NAVYMAN is offline
Mein Auto: 1994 525i
Trunk is open and latch stuck in closed position
94 525i. Trunk latch is stuck in the closed position & as a result I cannot close trunk. It seems to be jammed pretty good & I cannot get it to the open position. Any suggestions? I tried to insert photo, but can only get the web page it is on, so click on the web address & you will see my dilemma.
Old 05-27-2012, 11:27 AM
air_cooled air_cooled is offline
Mein Auto: E39 / E30 / E53
I don't have access to a wiring diagram at the moment but I doubt the lock is energized. Stick a screwdriver where the latch pin would typically be in the closed position and pull down.
Old 05-27-2012, 11:28 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
Have you tried prying the latch back with a screwdriver while holding the trunk release button down? Make sure the trunk release button is unlocked as well.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 05-27-2012, 11:58 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Does using the drivers door locking system help?
Old 05-28-2012, 10:48 AM
I'll give it a try. My son currently has the vehicle in Northern Calif but will be here Fri. (6-1). I will give it a try and forward this to him also. Thanks for your input.
