E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Hey everyone!
I really need your help guys! Many times I posted my questions on BMW forums and always got the right answers. Anyway, here is the video where you can hear these strange knocking sounds coming from my 325i 2002 engine: It started yesterday after I changed the oil, oil filter, fixed valve gasket sealant, changed a boot on first coil and changed all the spark plugs. The reason I had to open up the gasket is because I had a very bad oil leak into the first coil compartment. Turned out, my last mechanic did not properly place that rubber sealant piece on first three coils. So I fixed it and no more oil there now. Initially the car was misfiring really bad, so I thought that was the problem. However, now the car misfiring even worse I got the denso irodium sprak plugs from Advance Auto Parts... They said that Bosch were discontinued (weird). Anyway, they told me that the gap in spark plugs should be 0.44, but then I found on the net that it should be only 0.32... I tried both combinations... But still a bad misfire and knocking noise. And these are the codes that I have: P0300 P0174 P1085 P1083 P1349 P1353 P1351 P0420 If you anyone had the same problem, please share your experience! Thanks in advance! |
You`re running the wrong plugs, which has been known to cause problems. NGK BKR6EQUP are OEM-spec, try those. The noise might be a detached flap in your DISA valve.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
On my way!
On my way to exchange the damn spark plugs! Let's see if it do any better!
Changed the plugs... but didn't do any better :/ One guy said that it is back firing... What can be the reason for that?
| Bookmarks |
| Tags |
| engine, knocking, noise |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
