Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here.
Old 05-29-2012, 11:00 AM
qmafia qmafia is offline
Mein Auto: X5 4.8i
Loud Plane Noise while driving at 50 + MPG On a quite smooth road
I am not sure whats causing this but i hear a lound "Small plane propeller engine" noise when i go over 50+MPGs on a quite smooth road. I truned the AC off and i am not sure whats casuing it.....any thoughts:
Wheel Bearings? Possible
Tires ? - Doubt it
Susspension?
Anyone else had this issue?
Old 05-29-2012, 06:51 PM
tony(topaz,SMG) tony(topaz,SMG) is offline
Mein Auto: '11 335i,'02 M3, '08 X5,
My '08 4.8 sport has a similar noise that the dealer has not been able to diagnose.
Old 05-30-2012, 06:21 AM
Mein Auto: X5 4.8i
Thats interesting cuz i have a 07 4.8i as well. What has the dealer done to fix your issue (so we can rule them out)?
Old 05-30-2012, 06:33 AM
They first blamed the tires, so I replaced them. Then they blamed torn CV joint boots and they replaced the two front joints. Still had the noise after that. They put microphones under the car, but could never pinpoint the source.
Old 05-30-2012, 07:02 AM
Mein Auto: X5 4.8i
Thanks Tony, i will be sure to not try these things....I am leaning toward wheel bearings.....I'll take it in and let you know what I find out.
No one else had/has this problem?
Old 05-30-2012, 07:24 AM
It sure sounds like a bad wheel bearing, but it only makes the noise between 50-75 MPH. I would think a bad bearing would make more noise while turning even at slow speeds. BTW, I also replaced my transfer case fluid with no improvement of the noise.
Old 05-30-2012, 07:58 AM
ard ard is online now
Resident Curmudgeon
All windows closed? What are YOUR tire conditions??? (tony's car, his results and what did and didnt work are VIRTUALLY IRRELEVANT to you.... interesting perhaps, but you'd be foolish to rule things out based on "my car made the same noise" over the internet...)
Miles? Does it do the same thing in any gear?
Old 05-30-2012, 12:10 PM
Mein Auto: X5 4.8i
Point noted ARD! But i don't think the things that Tony's dealer tried to fix is the problem based on my knowledge of the car. it has 42K miles on it. Tires are in good shape as well.
Old 06-12-2012, 07:12 AM
Mein Auto: X5 4.8i
So I got my car fixed. Turns out it was the driver side wheel bearing!!! Cost me $850 to replace.... Not happy, since the car only has 42K miles on it. But the noise is gone!
Old 06-12-2012, 07:32 AM
chiefneil chiefneil is offline
Mein Auto: X5
Shouldn't that be covered under warranty?
Old 06-12-2012, 07:34 AM
Mein Auto: X5 4.8i
No, unfortunately it's an 07 4.8
Old 10-24-2012, 03:21 PM
shorkun shorkun is offline
Mein Auto: E70 4.8i
Same noise here
I'm having fairly loud fan type of noise coming from the engine compartment driving at 60 + MPH speed, at about 80 it's very prominent. I've asked dealer to look at it but they were not able to confirm it... Now I need to find similar 4.8 i to compare and prove it to the mechanics that it's not normal...
loud noise while driving
