E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Oil..
Ok so most people say that as long as oil meets the LL01 spec its ok and it doesnt make any difference.
Well, after trying alot of different oils the 10 years that I have owned an E46 (M52TU 320i 1995 cc and M54 2171cc 320Ci) I must say that oil makes a big difference in the performance, economy and sound of the engine. I have tried the following: 1. OEM BMW 5-30 LL01 2. OEM BMW 5-40 LL04 3. Castrol 0-30 LL04 4. Valvoline 5-30 LL01 syntec 5. Mobil1 0-40 LL01 6. Agip synpower 5-40 LL01 the engine performed very different with each one of these oils. For -1. Was more like a 5-40, thick oil, nice pull midrange, nice exhaust sound -2. Similar with -1 but strangely thinner oil, lasted more before blackening. -3. Horrible oil. I tried it only for 300km and changed it. Engine did not perform well, no pull on higher revs, and blackened really quick. Was watery and the car acted like a diesel car. -4. Nice oil, similar with mobil1 but cheaper. -5. excellent oil, both for durability, performance and engine sound. -6. Very similar but abit thinner than OEM 5-30 LL01, this oil is my favourite, giving you excellent fuel economy, and pull. Overall, I highly suggest Mobil1 for all climates, and agip 5-40 for hot climates.(like Cyprus) |
Seriously? With all due respect, I'm highly skeptical that it's possible for any human being to discern the impact on engine performance, sound, economy, etc. between a group of top quality oils. Maybe if you put the engine on a dyno with the different oils, but even that seems unlikely. Again, no disrespect intended, but I've never seen anyone make a claim like this before.
I confirm there is the difference:
#1 is good #3 is crap for BMW but Castrol 5W-40 is OK and similar to #1 OEM BMW 5W-30 #5 is very good But my favorite not in the list is LubroMoly 5W-40 100% synthetic made in Germany. However oil level in the engine makes huge difference as well. The lower level (close to low dipstick mark) the noisy engine and less pull. Last edited by LX-biker; 05-30-2012 at 05:13 PM. |
Sorry, but I think you guys have very vivid imaginations (and I mean that in only the nicest possible way
). It is true that in extreme applications (high end race motors), the type of oil will make a difference, but in a relatively (by modern standards) lightly stressed engine like ours, I don't think so. But then, I've only used the BMW branded stuff - not because I'm a snob for this type of thing, but because this is one of the few items the local dealer actually sells for a pretty decent price. |
And yes, the engine likes the oil to be topped up. |
I'm not saying it's impossible that different oils, particularly across different viscoities, could produce a slight difference it peak horsepower. I'm just saying that the difference in a modest output engine like ours would be too small to notice, unless you've comparing across drastic differences in viscosity, like 0W30 vs. 20W50.
I would suspect that if you took a car and performed a series of acceleration tests (0-30, 0-60, 0-100 if you can get away with it, etc.) under controlled conditions in both directions, with the engine, transmission, and differential fluids warmed up to the same temperatures in all runs, with each of the oils you have listed, the differences in times would not be statistically significant to a 95% confidence level. I could be wrong, but that's my strong suspicion. |
To be honest, all these oils that I have wrote above perform very similarly, besides the 0W30 castrol that I have used: So whatever you use, dont use this in an M54! So, to cut the long story short, dont use a 0W30 oil in an M54. If you are living in an extremely cold climate, and must use a 0W- rated oil, better use 0W40 Mobil1 LL01. It performs much better. |
Fair enough.
I have to compliment you on not getting defensive or upset because I challenged your conclusions - all too often on forums like this one, legitimate differences of opinion turn into ugly personal attacks, which is why I was careful to be as respectful I could with my wording. You sound like a good guy. And I promise to avoid Castrol 0W30 LL04! |
I am not a chemical engineer so I really cannot understand why this Castrol oil changed so much my engine's performance. All I know is that it is one (if not THE first) LL04 oil. I still keep the bottle, in case I can find an answer to my question. So, here it is again:
according to a guy named "charlie" at the bobistheoilguy.com forums, ll04 oils are inferior to ll01 oils since their low saps formulation contains low TBN values....
http://www.bobistheoilguy.com/forums...Number=1746122 Last edited by Fifty_Cent; 06-02-2012 at 11:03 PM. |
SLX Professional Powerflow BMW LL04 0W-30 __________________________________________________ ______________________________ Applications
__________________________________________________ ______________________________ Features / Benefits
__________________________________________________ ______________________________ Specifications / Performance
__________________________________________________ ______________________________ Storage
__________________________________________________ ______________________________ Health, Safety and Environment
__________________________________________________ ______________________________ Typical Characteristics __________________________________________________ ______________________________
__________________________________________________ ______________________________ The above figures are typical of those obtained with normal production tolerance and do not constitute a specification.
mobil1 0w40 characteristics:
You can't get the 0W-30 LL04 in the USA. And BMW doesn't want us USA drivers to use it anyway; seems that the higher sulfur content in our fuel and low-ash formula doesn't work as well as the older LL01. A lower TBN is much less an issue with the low-sulfur diesel and gasoline - fewer acid-forming reactions.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
