E46 (1999 - 2006)
Old 05-31-2012, 10:36 AM
PServe PServe is offline
Mein Auto: 01 Bmw 325ci
Crankshaft position sensor
Hi,
I wondering if anyone came across this. I have an 01 325ci with 268,000 miles on it. The car had a camshaft sensor code. I had the exhaust cam sensor replaced but the code persisted. I than had the intake cam sensor replaced. After replacing the intake cam sensor the computer threw a crankshaft sensor code. I've since had the crankshaft sensor replaced 2 times but the code won't go away. Also, after replacing the intake cam sensor the car will not kick over right away when starting it.
Any ideas??
Old 05-31-2012, 10:50 AM
tchavera tchavera is offline
Mein Auto: 323is
I'm not sure but maybe the timing is off?
Sent from my SCH-I500 using Bimmer App
Old 05-31-2012, 11:11 AM
KenG KenG is offline
Mein Auto: 00' 323ci 5sp mt
What is the exact code?
I know it's a dumb question but was the sensor replaced with an oem one?
Knock off brands tend to be faulty
We never really grow up; we only learn how to act in public.
-unknown
I like Chile Verde Burritos
Old 05-31-2012, 12:04 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
KenG is correct....using anything other than a factory BMW-issue CPS is a waste of time and money....most of the aftermarket junk is faulty or craps out in short order.
Also, if you`ve never replaced your VANOS seals, *that* could be causing the problem. The bad seals allow the cams to go to full advance prematurely, giving a false CPS code.
The road goes ever onward....
(R.I.P. Jever)
The sensors are from carquest do don't think it's oem. I was also told could be worn timing chain. Could a worn timing chain cause the crank sensor code? I'll get a oem sensor in and see if that fixes it. Thanks
Old 05-31-2012, 12:52 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
I'd start with the OE sensor. Timing chains aren't a common fault item on the M54 even with that many miles.
Old 05-31-2012, 01:00 PM
Fast Bob's Avatar
Keeping it surreal
I would bet LARGE sums of money against this diagnosis....
(R.I.P. Jever)
Old 05-31-2012, 04:01 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Febi is the OEM for the sensors, BTW.
They actually have the BMW part number on them, but come in a Febi box.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 05-31-2012, 04:17 PM
Thanks everyone for the responses. The timing chain diagnosis threw me a bit. I mad an appointment with a highly recommended bmw mechanic by me for Wednesday. I'll post what he finds.
Thanks again for the advice!!
Old 05-31-2012, 05:57 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
The timing chain is likely fine. I like Bob's VANOS diagnosis and the guys saying you need OEM sensors.
Old 05-31-2012, 10:09 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Camshaft not the crankshaft right?
Old 05-31-2012, 10:20 PM
Crankshaft. I had the intake cam sensor error first. As soon as the intake cam sensor was replaced the service engine light came up with the crank sensor. I've put 2 non oem crank sensors in but still having the issue and SES light will not get rid of the crank sensor code.
Old 05-31-2012, 10:26 PM
ztom's Avatar
Yours is double vanos? Search, maybe crank error is symptom of vanos problem? Heard exhaust side effects engine more when bad.
Old 05-31-2012, 10:28 PM
Fast Bob's Avatar
Keeping it surreal
Stored codes cannot always be relied on as being 100% accurate, sometimes they just point you in the general direction, then you have to use your "BMW Sixth Sense" to nail down the actual root cause of the problem (re-read Post #4 in this thread).
Also, after replacing sensors, it normally takes several cycles of driving 15 or more miles before the system will clear the old stored codes.
(R.I.P. Jever)
Old 05-31-2012, 10:38 PM
I've been driving the car for 2-3 weeks with this problem and over a week since the crank sensor was replaced for the 2nd time and the code won't clear. The car having trouble turning over when starting has been going on for 2-3 weeks also, since the crank sensor code came up. I saw post # 4 and I never changed the vanos so it could definitely be that.
I'll keep you posted after I bring it in.
Old 05-22-2013, 10:44 AM
SDpnoy SDpnoy is offline
E46Fanatics
Mein Auto: BMW 330Ci
So what was the cause?
cam position sensors, crankshaft sensor;
