Old 08-04-2012, 02:06 AM
seyfeichai seyfeichai is offline
Mein Auto: F30 328i
hi,
i have a big problem here.
While trying to code the adaptive headlights setting, i must have messed up with some other configuration such that the wiper is haywire now.
I only noticed when it rain today.
1) when set to auto mode, the wiper stop at the exact position when i release the auto button (it does no longer complete a full cycle and reset at the resting place).
2) when i push the wiper stock downward (for manual), the wiper will stop the moment i release. Again it will not reset to the resting position.
Has anybody experience the same thing?
I think i recalled how i ended up in this state.
There was a previous occasion that i pressed "code" instead of "Code FDL". The settings must have reverted to the default based on the PSD files (my guess).
I have since made a copy of my friend's 328i.
Can somebody advise how i could load the whole CAFD files for "Fem_body" into my car?
Old 08-04-2012, 07:24 PM
wnrussell wnrussell is offline
Real Car PC
Send a message via AIM to wnrussell Send a message via MSN to wnrussell Send a message via Yahoo to wnrussell
Mein Auto: 2015 428i xDrive GC
Originally Posted by DreamCar View Post
Guys we have entire forum for us... please create a seperate threads.... and you have more visisbility for your question
Is there a thread for "Transfering your phone ring tone to your car, like in the OP?
I see the 3001 TELEPHONE_PARAMETER, but am unsure how to get the MP3 to the car.
Old 08-04-2012, 07:35 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
I haven't messed with it, but I assumed that with 3001 TELEPHONE_PARAMETER / INBAND_RINGING, the ring tone of the phone was streamed via Bluetooth.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 08-04-2012, 08:37 PM
April1 April1 is offline
Mein Auto: X3 2011
You can find this and many other settings in available cheat sheets, please go through them and pickup what you like.
Old 08-04-2012, 08:49 PM
I think unlike many, he actually read the Cheat Sheet, and was aware of the INBAND_RINGING code, but believed he had to, and was asking how to, put the actual Ring Tone MP3 in his car to go along with the INBAND_RINGING code, which shouldn't be necessary. In any event, opening a new thread would be the way to go.
Old 08-05-2012, 09:36 AM
Real Car PC
Sending your phone ringtone to your car
Thread started http://www.bimmerfest.com/forums/sho...d.php?t=637386
Old 09-09-2012, 09:15 PM
Jrbust91 Jrbust91 is offline
Mein Auto: 2009 750Li
Can the Esys software be installed on an external hard drive?, if yes, what files must reside on laptop?
Old 09-09-2012, 09:31 PM
Mein Auto: X3 2011
Technically ESys can be installed on an external drive but as part of the libraries get registered to the laptop, you can't change the laptop and connect the HD to another laptop. Yes this way you get the additional disk space. Every thing will be installed on ext HD. You can create a short cut on the desktop. It has it's negative side that it reduces the reliability during coding. We would not like to have any interuption of any kind when cafd data is being transferred to your car.
Old 09-09-2012, 09:49 PM
You should be able to install E-Sys to your C Drive, which is about 200 Mb total, then copy the C:\ESysData to an external drive and put your PSdZData in this folder, which will total about 20Gb. You will need to go into E-Sys Settings, Program Tab, and Data, and set the path to your external ESysData location. If the external drive assignment is static, then you should only have to do this one time. If the external drive assignment is dynamic, then you will have to update the ESysData data path in E-Sys every time the drive letter assignment changes. I would leave your EST Token somewhere on the local C Drive, otherwise you would also have to maintain the token path in E-Sys under E-Sys Settings, EST Tab, and EST, every time the drive letter assignment changes too.
You should also be able to put the EDIABAS folder on an external hard drive, which is another 500 Mb. There is no configuration settings that needs to be changed either for this.
Old 09-10-2012, 06:42 AM
Sharbotcom Sharbotcom is offline
Mein Auto: F10 535xi MSport
One of the tricks in Windows is to assign a static drive to a specific portable drive. The way to do that is to attach the portable drive and run diskmanager (diskmgmt.msc - either type it in at the run prompt or you can find it under the administrator options). Once diskmanager is running look for your portable drive and right click on it. Select change drive letter and assign a high value like P. Once completed everytime you hook up that portable drive to your PC Windows will recognize it as drive P (or whatever you assigned to it). That way you only need to make the path entries in E-Sys only once.
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, M Sport Package, 316, 322, 3AG, 5AD, 5AG, 5DL, 609, 620, 655, 677, 6FL delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
Old 09-10-2012, 07:03 AM
Thanks for the info, I will give it a try.
Old 09-18-2012, 08:58 AM
Beer55 Beer55 is offline
Mein Auto: 335i E92
Help!!!
I wanted to encode the data V47.4 and get the following error :-(
Kombi
cdDeploy ProcessedWithError
cafd_00000069-008_01_018 Not Executable
Old 09-18-2012, 09:03 AM
What is the actual E-Sys Error code in the brackets []?
What is your EST Token file name?
Old 09-18-2012, 09:07 AM
Mein Auto: 335i E92
Transaktions-Report: Aktion: FDL Codieren
KOMBI [60]
cafd_00000069-008_001_018 Not Executable
Old 09-18-2012, 09:12 AM
KOMBI [60]
No. The [60] after KOMBI is the ECU's address.
I am looking for something like this:
File for "cafd_0000000f-005_022_007" not found! [C012]
Please advise on the filename for your EST Token.
Old 09-18-2012, 09:13 AM
Mein Auto: 335i E92
I work with a Esys 3.20.
EST token I get to and has always worked.
Old 09-18-2012, 09:16 AM
Mein Auto: 335i E92
So eine nummer kommt Nicht :-(
DAS IST der Name der EST: 2012.03_eSys_esys
Old 09-18-2012, 09:30 AM
Ok. I think if you downloaded the readily available E-Sys 3.18.4 you would find that you have no problems, as the EST Token is authentic.
I have a pretty good idea of what you have, and if it is what I suspect, you need an updated token as a change in the latest PSdZData necessitated a revision / update of that EST Token. You should contact the Token supplier for the update.
Mein Auto: 335i E92
[IMG]file:///C:/Dokumente%20und%20Einstellungen/user/Desktop/E-Sys%203.20.png[/IMG]
Old 09-18-2012, 09:32 AM
Mein Auto: 335i E92
Ok Best thanks for the help.
You gave me a link for the token with the version 3.18?
FYI. I do not think the [IMG] tag works with local hard drive files. For this, you use the file upload function. The [IMG] tag is for images hosted on another website.
Old 09-18-2012, 09:33 AM
I did, or you need the link?
Old 09-18-2012, 09:35 AM
Mein Auto: 335i E92
I need a Link.
Sry i dont speak Englisch :-(
Old 09-18-2012, 09:41 AM
I need a Link.
PM Sent.
FYI. You do not need to uninstall 3.20. Just install 3.18.4 to its own directory, set the data path to the same data path as 3.20 (e.g. C:\ESysData), and set your EST path.
Old 09-20-2012, 05:48 PM
tester00 tester00 is offline
Mein Auto: BMW 335i E92
Hi,
i am a newbie in this BMW coding. I have coded some things in my F13 650i. But i dont can code the HUD_CIC, because i dont have a actually psdzdata.
Where can i get the newest psdzdata.
I need a link please.
Many thanks
