Repairing Navigation DVD Drive Laser Head - Bimmerfest - BMW Forums
Old 05-31-2012, 10:29 PM
skybmray's Avatar
skybmray skybmray is offline
Mein Auto: 2005 745li
If you ever get the dreaded MAP CD NOT FOUND or it takes a very long time to initialize, its highly likely that the DVD laser head is gone on the unit and needs replacing. After replacing the laser head my DVD Nav unit it just takes seconds to fire up and read the DVDs no problems I got to a point were I was carrying a tomtom in the glove box, when the Nav would just stop or wouldn't initialize again.
I looked on ebay and the prices for second hand units and they were extremely high and also considering you wouldn't know the state of the DVD laser head if it was going on it way out. So I opted in repairing it my self.
I attempted this repair today as my replacement laser had arrived from Germany. Took about 2 weeks to arrive. You can either buy the whole unit http://www.navigatie-onderdelen.nl/e...roducts/PH2038 which would be a straight forward install. I recommend this for people who are too sure about there soldering skills.
or just the DVD laser head for 23 euros if you handy with the soldering iron. http://www.navigatie-onderdelen.nl/e...roducts/PH2050
Tools required, pcb board type soldering iron, desoldering braid or desolder pump, Torx T4 to T8 screwdrivers and some watch precision screwdriver set.
Step 1 take the DVD unit out of the car, I didn't disconnect the battery at the time as the unit was in sleep mode.
Step 2 Slide the black mounting bracket.
Step 3 Lift the top of the DVD unit to expose the drive.
Step 4 Remove four torx screws holding the drive in.
Step 5 Do not remove the cable that is attached to the cable otherwise you will damage the ribbon and connector, it is too brittle and will break. instead remove the cable from the other end by lifting the board to the right up.
Step 6 Remove all other connectors as in the picture, so the drive is bare with just the ribbon.
Step 7 Desolder the shield from all four corners before lifting up to expose the DVD laser ribbon. I originally used the desolder pump it was no good, instead use the desolder braid instead much better. The desoldering pump was good as **** on a fish.
Step 8 Once heat shield is off, remove the DVD laser ribbon.
Step 9 Remove two screws on the opposite side that shield the laser from the top. Ensure you make a mental note or picture of the shield to how it is located, you will need a torx and a very small Philips head. The laser shield actuates a switch on the bottom and on the right is seated on a spindle.
Step 10 remove another two torx screws at the top of the two guide bars for the laser head.
Step 11 Gently prise the bars up and slide the laser DVD head out.
Step 12 On the new DVD laser head ribbon there will be two solder bridge points, you must remove these before the laser is operational ! use desolder braid and heat the top with the solder iron gently and is should come right off.
Step 13 Installing the laser is just reversing the process, ensure the DVD laser doesn't touch anything when you slide it on the bars. Use tweezers for this to lift the bars up it helps.
Step 14 Install back to car and enjoy the NAV again with super fast access to the maps
Pics below
ID:	327418   Click image for larger version
ID:	327419   Click image for larger version
ID:	327420   Click image for larger version
ID:	327421   Click image for larger version
ID:	327423   Click image for larger version
ID:	327424   Click image for larger version
ID:	327425   Click image for larger version
ID:	327426   Click image for larger version
ID:	327428   Click image for larger version
ID:	327429   Click image for larger version
ID:	327430   Click image for larger version
ID:	327431   Click image for larger version
ID:	327434   Click image for larger version
Old 06-01-2012, 12:13 PM
skybmray's Avatar
anyone find this useful ?
Old 06-01-2012, 01:17 PM
dannydos's Avatar
dannydos dannydos is offline
Mein Auto: 745i
I'm having some issues with my cd nav player. Any tips to pin point which part is bad? Also the desolding pump that you are using is to small. I use a bigger one and gets the job done every time.
///E65 745I///22" Asanti AF128///H&R springs/// 12" JL W7///
Old 06-01-2012, 02:27 PM
skybmray's Avatar
sure you can get a replacement laser for the CD unit in the US for about 20 bucks. The procedure would be the same just the laser head be different.
Old 11-06-2012, 09:49 AM
1bad540's Avatar
1bad540 1bad540 is offline
Great writeup, I dont think its the head in mine tho, the screen is just keeps rolling, I ordered a replacement off ebay, so well see if that solves the problem. Used mk4's are quite expensive. This is in my 05 x5,
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 11-08-2012, 02:25 PM
bayerisheteknik bayerisheteknik is offline
Mein Auto: ...
Old 04-13-2014, 07:12 AM
jean d jean d is offline
Mein Auto: 2008 X5 3.0i
Anyone have a US source for the replacement laser?
Old 04-13-2014, 08:24 AM
JC 2001 750iL JC 2001 750iL is offline
Mein Auto: 745Li, 750iL
Great writeup. Thanks for sharing.
Old 04-15-2014, 05:46 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
This should be posted in the DIY section or added to Paper's helpful topic list.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 01-23-2017, 12:15 PM
jp96885 jp96885 is offline
JimmyRay
Mein Auto: 2008 528XI Sport
Will this DVD laser head fit a 2008 528XI?
My navigation system has an error message "cannot find DVD"
Old 01-23-2017, 04:11 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
bimmerfest Supporting Member
Mein Auto: 05' 760li,94' H1,08'Smart
Pull the head unit out, and read the tag. It'll tell you what model it is. I believe these units were made by Alpine for BMW. The company that is linked will probably have info for you.
The current link shows not for a seven series however it list some models that it is for.
Search their site once you know what year model is. I know with the seven series there was several generations of DVD Nav units.
Old 01-23-2017, 04:48 PM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
I had the same problem a few years ago and replaced the entire drive assembly with a replacement part from the dealer for just under $200. Nice write up, glad to hear you figured out a very affordable solution to fix this all too common problem!
http://www.bimmerfest.com/forums/sho...on+replacement
Old 06-04-2017, 09:50 AM
mathat mathat is offline
Mein Auto: 730d
anyone got a supplier for the laser unit - I can not find a black laser anywhere, they all seem to be out of stock ! (there are a couple on ebay for 50 + , but I might as well by the whole unit at that price)
also if I was to replace the drive I noticed a note at the bottom of the page "Note: Use only original DVD's because pirated DVD's can damage the drive" -does anyone use genuine DVD's ?
Old 06-20-2017, 03:04 PM
domovus domovus is offline
Mein Auto: BMW 320D
Which model I need?
I have problem with my navigation laser. How to find out which model I need (M2/M3/M4)?
Thank you.
