How to clean your Secondary Air Valve to prevent the pump from failing. - Bimmerfest - BMW Forums
Old 06-01-2012, 05:03 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
I've cleaned my sec air valve a few times in the past so it doesn't really look that bad in the before pic.
When enough carbon builds up the valve will not close on it's seat allowing exhaust and water (a combustion byproduct) to enter the secondary air pump, which over time will cause the pump to fail and drain your wallet.
This is a few hour job on a V8 if you are going to remove the air tube between the heads.
On an I6 it should be a much quicker job.
2000 540/6 Slightly tweeked...everywhere
Old 06-01-2012, 07:56 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
Thanks for posting Jim. My weekend project. I seems to always find a little project to do on the weekend.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 06-01-2012, 08:00 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Pretty slick, Jim.
I just swapped the old check valve with a new one, and changed the salmon relay as well. I still have the old relay, but the old check valve has seen the garbage bin.
I also had that carbon crud on it.
Not sure how the v8 is, but on the i6 there is a layered metal gasket that has to be replaced once you pull out the check valve. The gasket is not reusable, because once used, it molds on both mating surfaces. The new gasket seal is much thicker compared to a used one. Also, the used one on my car came off in pieces. Some parts were "glued" to one side (check valve), and some on the other side. Some other pieces just flaked off.
Old 06-01-2012, 09:29 AM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
I simply replaced mine for $99. Much easier!
Use www.furiousmethod.com to find best prices @ parts..
In fact, here it is:
http://www.trademotion.com/partlocat...egoryID=174653
Or, email directly:
Jason Reighard | Internet Parts Manager | getBMWparts.com
BMW of Silver Spring 3211 Automobile Blvd. Silver Spring, MD 20904
Email getHelp@getBMWparts.com | AIM Jason at Tischer
Old 06-01-2012, 10:50 AM
The gasket is the same on the V8, it's a Grafoil gasket. Once you tighten the valve down it compresses the gasket.
Old 06-01-2012, 10:57 AM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
+1. I appreciate Jim's tip, and I believe cleaning the valve is better that doing nothing, but it is also a good idea to consider replacement at some point. Clogging from crud is not the only failure mode....I had the valve fail on my car while under warranty at around 35k miles. Dealer replaced the valve, hoses and air pump.
At around 150k miles I went ahead and preventively replaced the valve and gasket, less than $90 online a year ago..
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 06-01-2012, 11:34 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
I didn't know this valve was amenable to cleaning for maintenance. I'll buy a spare gasket and give it a shot. Thanks for the tip, Jim.
Old 06-01-2012, 11:50 AM
hotstepper hotstepper is offline
Mein Auto: 528i
Great tip thanks I'll check/clean mine over the weekend
Old 06-01-2012, 01:48 PM
Anything can fail prematurely, at least your's was under warranty. Mine is original, 12 years old and 137K on it.
Idler pulley bearings are next on the list of things to be done.
Old 06-01-2012, 02:09 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
FTW Trump 2020!
Mein Auto: 2001 540i/6
Dinan valve covers? Dyno results? Jk
If you plan to replace the idlers i can give you some tips on how to order the parts correctly.
Basically the only pulley available by itself is the one on the lower right corner.
The two on a/c side as well as the two in middle are NOT the same size as the lower right corner pulley. Dont ask why i know this. Ordering a bunch of the same pulley wont work. The two in the middle as well as the two on the a/c can only be acquired by buying the entire tensioning unit.
Although according to realoem the prevanos m62 used 70mm pulleys which just happen to be the size on the tensioning units of the m62tu. But then again its prob best to get the whole unit so you have a new tensioner too.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 06-01-2012, 03:38 PM
I understand, my point was after 120 or 130k+ miles, one might just want to consider replacing with new.
I had my pullies, tensioners and belts done at 123k. Part of replacing just about the entire cooling system...rad, exp tank, cap, thermostat, water pump, fan clutch, all hoses, etc...long list of stuff.
+1 on the pullies, they are sold as assemblies, not individually.
Old 06-01-2012, 04:21 PM
Awesome link, thank you for sharing it!
What a time saver this will be.
Old 06-01-2012, 04:49 PM
Steve gave me the D stickers, I do have his engine and CAI downloads.
475 HP 540lb-ft.
I'm just taking the idlers out to clean the old grease out and repack the bearings.
I do it about every 3 years after one of the bearings went dry, overheated, and melted the plastic idler.
AAA flatbedded me back home.
Edit:
I'm pretty sure I remember seeing individual idlers availabe from Dayco. If I find the link I'll post it.
540 M-Sport, I did buy new idlers about 5 years ago so I just regrease and swap them.
I did the complete cooling system about 60K ago, Zionsville radiator and electric fan.
Old 06-01-2012, 06:32 PM
Regreasing is definitely helpful, and your intervals insures the health of the bearings, but again, the heat cycles of the plastic is also a consideration, and at some point you have to seriously consider replacement. Problem is the age issue is a guess at best...5 years? 10 years? Who knows?
540 lb/ft is AWESOME!
Old 06-01-2012, 07:19 PM
Under hood heat is definitely a problem. So far I've been lucky, I always open the hood when I pull the car into the garage. None of my plastic has failed yet...knocking on wood.
The radiator was replaced as a preventative measure.
Old 02-28-2016, 01:01 AM
dave321 dave321 is offline
Mein Auto: E64
Hi, could you repost the pictures as I don't seem to be able to open them. The pump on my e64 has just started to make a noise so want to clean the system first before replacing the pump itself, thanks
Old 04-03-2016, 12:13 PM
Dave,
Just saw your request, only because sixpot-simon sent me a PM asking the same thing.
Here's a link that will bring you to the 6 pics. Click on the pic to expand it, then on the side arrows to go forward or backwards.
You can also use turpentine to dissolve the carbon.
https://onedrive.live.com/redir?resi...t=folder%2cJPG
Old 04-03-2016, 03:29 PM
computiNATEor's Avatar
computiNATEor computiNATEor is offline
(oOO\(|||) (|||)/OOo)
Mein Auto: 2 x 530i Sport
Dave,
It would be especially helpful to anyone in the future to simply use the advanced editor to attach them to the post. Use the "Manage Attachments" button.
Nate J.
RIP, Seabiscuit - 03-11-03 530iA Sport, Sapphire Black/Black. T-boned 03-01-2017. 155,861mi.
Take 2 "Otto" - 04-25-2002 530iA Sport, Toledo Blue/Sandbeige. 142,000mi and counting.
Take 3 "Manuel" - 11/??/2001 530i5 Sport, Toledo Blue/Grau. 191,000mi and counting.
Old 04-03-2016, 03:58 PM
sixpot_simon's Avatar
sixpot_simon sixpot_simon is offline
Mein Auto: E30, E39
Hi Jim,
Many thanks for your efforts getting the photos back up. I look forward using them soon to inspect/clean my sec air valve
Cheers,
Simon
