The X5 SAV Forum
Old 06-01-2012, 10:11 AM
BStrait BStrait is offline
Mein Auto: BMW x5 2001
X5 shakes when stopped. RPM fluctuates. Cylinder 6 misfire code. Low Power.
BMW 3.0 X5 2001. 175K miles. Recently, my service engine light came on with no problems. Subsequently, when leaving my car idle for over a short amount of time, the car would begin to shake. If I tried to drive away my RPM's would not shift until 3500 and I experienced low power. The problem is fixed if I restart my car and drive away. However, the problme comes back every time I STOP. A BMW fault code reads P0313 Misfire on Cylinder 6. When stopped, if I put the car in neutral, it takes longer for it to start shaking, and if I give it gas, it takes even longer to start shaking.
I have low compression in cylinder 6 when the car is shaking. No leaks in the gasket. Already changed the spark plugs and coils. Cleaned the MAF. Did fuel injector cleaner and oil stabalizer. Also, I get a clicking noise from the engine at times, often when my oil is low. I have leaking oil.
FML. Please help.
Old 06-08-2012, 02:09 PM
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: 01 525i, 01 X5, 91 Z32TT
You have the same engine as E39 530i. (Delete bad link)
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 06-12-2012, 07:10 AM
Your link just takes me right back to this page.... Can you repost your link please.
Old 06-12-2012, 11:34 AM
Sorry.
Here it is http://www.bimmerfest.com/forums/sho...419&highlight=
