Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here.
Old 06-01-2012, 12:56 PM
tx_bmw tx_bmw is offline
FIFO
Mein Auto: 2012 X5 35i on order
2012 X5 35i with M-Pack - Interior Noises
I am having some frustration with my new X5. At certain times and under uneven road conditions (but sometimes under ideal conditions), I hear a significant amount of popping and creaking coming from somewhere around the B-pillars. If I actually press on the pillars (the area below the seatbelt), there is some flex and the plastic creaks a bit. Does not happen all the time, so I am really not sure if the areas are not seated properly. Has anyone else had this experience?
Thanks in advance.
In the Garage
|2012 X5 xdrive35i SAV|Carbon Black|Oyster|Dark Bamboo|M-Package|
Sold
|2008 E90 335i|Black Sapphire|Black Dakota|Dark Burl|Prem|Sport|Cold|Step|AS|Navi|iPod|
Old 06-01-2012, 11:36 PM
RPsX5d RPsX5d is offline
Mein Auto: X5 Diesel xDrive35d
Near certain you have the same problem I had . . . a known issue and BMW has a procedure for it . . . involves adding a Teflon tape . . . here is what they did for me
That solution worked for nearly 18 months then the noise came back . . . a few days ago they removed the old Teflon tape and installed a new one plus adjusted the front passenger door (that is where the noise was coming from). Not sure how long this will last.
An easy check - lower the window about a quarter inch from the side/door where the noise is coming from . . . you may pick up some wind noise, but the popping/creaking sound should disappear. Also, in my case, this noise was never there at hwy speeds. Easiest way to reproduce this noise was to go over a speed bump at about 5 mph - one tire at a time . . . i.e. go over the bump at an angle so one tire hits the bump first.
Here is another thread related to this issue . . .
Old 06-04-2012, 01:53 AM
Billyraymallard Billyraymallard is offline
Mein Auto: 2011 x5 35i
Have the same. Seems a trim issue. Haven't brought in yet as noise isn't too bad. Let me know what happens.
