Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 07-12-2012, 09:38 AM
konzM5 konzM5 is offline
Mein Auto: 1989 M3
Blinker stay on (left) with new turn signal switch installed
I have a 2000 BMW M5 and my left blinker stays on when it's in the neutral and top position, but when I put it on the Bottom position (left blinker) it turns off. I just replaced the turn signal switch and it still does the same thing. The right blinker does not go on at all. Any suggestions?
Thanks,
-keith
Old 08-30-2012, 10:39 PM
Steven Ferrario Steven Ferrario is offline
Mein Auto: 2001 M5
Bulb might be burned out...
Old 09-29-2012, 09:57 PM
///fast5 ///fast5 is offline
Mein Auto: e39 Bmw M5, e46 Bmw 330i
Check the connector of bulb make sure no oxidation or short in connector and check wires if they arent broken inside. Slightly pull wires from behind the connector and broken one will come off ez so you can fix it.
