Old 06-03-2012, 04:42 AM
svache's Avatar
svache svache is offline
Mein Auto: 2012 F30 328i
Cheat Sheet Codes
I hope Sean (ImSW1) doesn't mind I'm stealing his idea (and some of his text lol) for this thread, but I think it's ok
If you have located a new module that alters how the F30's act, please post it here so I can add it to the current F30 cheat sheet.
Please only post those codes that you are now are working, or add notes that can be listed in the 'description' column of the cheat sheet.
Please do not ask questions or any requests for modules in this thread. Like with the F10 cheat sheet thread, we should keep this one clean so we get all the new modules that we tested and found to alter the cars.
I will try to keep an updated cheat sheet list for the F30 attached to this first post (like I did on another site, the file will be in the "F30_Cheat_Sheet_YYYYMMDD.pdf" format so you can see when the last update was to the cheat sheet
'12 F30 328i w/ A17, LCLY, ZLL/7S2, ZCW, ZDA, ZPK, ZPP, ZPS, ZTP, 205, 2VL, 302, 3DZ, 415, 417, 522, 524, 5AC, 5AP, 5DP, 615, 6AA, 6AB, 6NF, 6NL, 6NR, 6UH, 6VA, 6WA, 8S4, 8TH (yes, that's all lol)
Retired: '09 E70 X5, '04 E46 M3
Old 11-07-2012, 04:30 PM
MrTowers MrTowers is offline
Mein Auto: 335 '14 MSport
Thanks Svanche for putting this together, it is really helpful but there is a problem with the margins. Can you enable the "wrap" option in the source file and create the PDF again so the comments fit? or send me the original file and I'll do it for you.
Thanks,
Old 11-20-2012, 12:40 AM
MarkyMarkOZ MarkyMarkOZ is offline
Mein Auto: F30 328
Is there any update to this?
Old 12-22-2012, 06:54 PM
ahmadr ahmadr is offline
Mein Auto: F30 (N20, 7/12)
Svanche,
You may want to add this to your cheat sheet
http://www.bimmerfest.com/forums/sho...d.php?t=665581
Old 12-29-2012, 05:51 AM
donsultan donsultan is offline
Mein Auto: 750Li F02
thanks for the cheat sheet
Old 12-29-2012, 09:04 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
Need to add digital kombi to it too
ITs under Bkombi
