Old 07-29-2016, 06:41 PM
Cardiac Cardiac is offline
Mein Auto: Miata, Tracker
Steering Wheel
On our `09, the satin finish on the plastic buttons surround is coming off. Like to take those two pieces off and refinish them. Easy to do?
LOL the wheel on our 330ci is still perfect after 15yrs.
Old 07-29-2016, 06:45 PM
Q4's Avatar
Q4 Q4 is online now
Mein Auto: 2008 x3
Yes. There are three small torx screws in deep recesses behind the steering wheel. Three for each side trim piece.
I recovered mine in 3m matte black vinyl wrap and they look like new oem trim pieces.
http://www.bimmerfest.com/forums/sho...516&highlight=
Tim
Cincinnati
Old 07-30-2016, 10:54 AM
Took a look there are two and a third at right angle to them. I'm assuming the two are for the cover and the third is for the airbag?
Ours is an 09
Old 07-30-2016, 01:10 PM
Q4's Avatar
Q4 Q4 is online now
Mein Auto: 2008 x3
Is your steering wheel of a different design than my steering wheel?
Tim
Cincinnati
Old 07-30-2016, 04:30 PM
Looks the same as yours. Now, I'm going to take another look but there is a screw at right angles to the other two I'm seeing
Old 07-31-2016, 02:46 PM
Q4's Avatar
Q4 Q4 is online now
Mein Auto: 2008 x3
so did you break one of the mounting points for your trim panels yet?
Tim
Cincinnati
Old 07-31-2016, 08:05 PM
UFRIENDLY's Avatar
UFRIENDLY UFRIENDLY is offline
Mein Auto: 2005 x3
I put cat was on mine to protect. Still look new. Once a year or so. Liquid mcquires in my case.
Old 08-01-2016, 11:03 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Wat?
Old 08-01-2016, 11:47 AM
Q4's Avatar
Q4 Q4 is online now
Mein Auto: 2008 x3
The third at a right angle is how you remove the airbag. You just slide in a torx or whatever screwdriver which pushes a lever and releases the airbag. Have to do both sides.
It's possible there are only two screws holding on the trim piece. I could have a faulty memory on that bit.
Be very careful when you remove the trim bits. I removed mine with the airbag in place successfully.
For zero chance of breaking the under mount points you could remove the airbag first using the above method. If you unplug the airbag with the battery connected you'll get an airbag light that will need to be reset with a scan tool. However you could probably just pull the airbag away from the wheel leaving it connected.
I would just gently do it with the airbag in place.
Tim
Cincinnati
Old 08-01-2016, 11:48 AM
Q4's Avatar
Q4 Q4 is online now
Mein Auto: 2008 x3
Dude. Seriously. Don't do that to your cat. They don't like that.
Tim
Cincinnati
