BMW Coding and Programming
Discuss coding options and features on your BMW here. |
M HUD Project
Let's discuss how to enable M-HUD on non M5 vehicles.
It seems it was done on the E60, even though early E60 threads people said they traced it to the DME, and the problem was there was no way to load the M5 DME on the E60. Clearly the M5 was using an SMG transmission vs an Automatic, although both were 6 speed. With the F10 we have different transmissions, and different number of gears. So far I have enabled the M-HUD option in the HUD Display Options but I can't check it. I have also added digital tachometer to the Control Menu Info options, but also can't check it. QUESTION: DOES ANYONE HAVE ACCESS TO THE METHODOLOGY USED TO ENABLE M_HUD on the E60?
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP |
@Stealth.Pilot,
Can you please point for me where the "HUD_VARIANTE" setting is located? Thanks. Edit: Actually I find a "M_VARIANTE" but not a "HUD_VARIANTE" Also I find a "MDRIVE" But not a "M_DRIVE" Can you please correct as necessary or point me to the correct place? JEG23
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR Last edited by JEG23; 06-04-2012 at 07:30 PM. |
I'm actually looking into this on my F30 and I found an option called "HUD_M" which is set originally to nicht_aktiv, it is in a part where the system gets to hear whether or not it has certain options or hardware, the description for this option is: "This describes whether the car has a M-Headup Display (M3/M5/M6).", now I'm wondering what you guys think of this one.. it kinda looks as if it is a different HUD than the ones standard in our cars.. if so, coding it might be a bit difficult. I haven't tested it out yet, too late for doing that now, but will do soon to see what it does if I enable this function
'12 F30 328i w/ A17, LCLY, ZLL/7S2, ZCW, ZDA, ZPK, ZPP, ZPS, ZTP, 205, 2VL, 302, 3DZ, 415, 417, 522, 524, 5AC, 5AP, 5DP, 615, 6AA, 6AB, 6NF, 6NL, 6NR, 6UH, 6VA, 6WA, 8S4, 8TH (yes, that's all lol) Retired: '09 E70 X5, '04 E46 M3 |
This was the last parameter I looked in to when I gave up M HUD ... Good that you and Jeg23 are working in this hope you folks will crack this |
Thanks to JEG23 (He is one of our very active memeber but he is always behind the screen
) we have list of parameters whihc we think has some relation to our M HUD.I have tried some of these settings when iinitially worked on HUD thing. i have added my observation CAF [HU_CICHB] 3000 HMI, 78 M_DIGITAL_TACHO_EINH (NA)-- added no difference HUD_ACTIVATION (NA)-------Acts like switch HUD on/off (Redundant) M_KEY_SETTINGS (NA) M_DIGITAL_TACHO (NA)---added no diiference MDRIVE_CONFIG (2_menu) MDRIVE (NA) HUD_M (NA)--added no difference MDRIVE_RUEKO (NA)----Any body know what is the meaning of Rueko? CAF [KOMBI L6 BO] 3000 Anzeige_Konfiguration, 2C M_DRIVE_BLINKFREQUENZ (wert 01) M_DIGI_TACHO_EINHEIT (pia) 3003 FZG_Ausstattung, 06 M_VARIANTE (ag_variante) 3008 PIA_Einheiten, 08 KI_PIA_ANALOG_RW_KVA (Act) KI_PIA_M_SPORT_DIGI_TACHO (NA) HUD_PIA_M_SPORT (inact) KI_PIA_MVERBRAUCH (NA) and all PIA pertains to including this parameters in your profile export... |
I was playing a bit with these functions on my F30 last night and I noticed that when I turned the digital tacho on (in my iDrive settings menu), it would remove my digital fuel consumption meter thingie (dunno what you call it, it's located below the tachometer on the enhanced instrument cluster.
I think that is also described in th "Cheat".
I'm honestly not sure this is possible. A friend of mine sent me some in-car footage he took for me of the M5 in Germany. (I'm moving there, and naturally, I've ordered one.)
The layout of the instrument cluster's lower third is completely different. It has a larger gear indicator, the M-Drive settings, and more. The part numbers are different. The cluster feeds the HUD. If the cluster doesn't have the software, it won't be able to drive the HUD. The software versions in our cars are probably old, so even if it did exist, it may not be possible to activate it. I don't want to discourage anybody, but I think this might be a stumbling block. The E60 was a different beast.
![]() 2013 ///M5 Alpine White · Sakhir Orange Full Merino Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods Last edited by wdimagineer; 06-07-2012 at 12:08 AM. |
Also the same observations can be made with the E60.
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP Last edited by Stealth.Pilot; 06-07-2012 at 02:49 AM. |
But the video posted by stealth says other wise. Cn some body tell if it is just RPM that get displayed as part of M HUD? |
M HUD on the E60 was a breeze...that was a smart HUD, not like the the new pretty but dumb HUD in the F series.
All you had to do was activate some M-Drive parameters in CCC and in HUD and you had the option of showing the M Tach. The only problem we had with activating the MDrive functions is the top function button on the steering wheel stopped working as the car assumed that was where the M button was. I've retrofitted HUD on E60's 5 times and was really surprised the first time I coded an F10 with HUD that it is basically a display with no real brain of its own, it is fed almost completely from the KOMBI. In E60, you could activate things like HUD blinkers by coding the HUD directly. EDIT: The exact parameters - M view on HUD E60 CAPPL: MDrive aktiv HUD_M aktiv HUD: M_SPORT_HUD aktiv Last edited by itschase; 06-07-2012 at 07:38 AM. |
But the system stoped responding to one the button on of the steerig assuming it as a M Mode button... So we either loose the Mode control or the Cruise control That gives me a good lead... Too bad i dont have my car with me now! Last edited by DreamCar; 06-07-2012 at 07:53 AM. |
Thanks Chase, I think we have all these parameters in Kombi.. May we should dig little deeper... |
Since SLI is not going anywhere...... checked on M HUD for a change... No luck but this is what i see for now...
Sorry Iphone Video ! |
Enabled every thing ....we have the UI as shown in above video but we are missing the back end! not sure where the back end is? Kombi doesnt have anything else for M HUD
I'm at the same page. I have everything you showed in your video, but nothing really works. Like with you it looks like something is missing..
Yeah we are missing teh system which responds to the input.. we just have empty UI there is no system which can store/respond to our UI clicks
I also tried pretty much all available
Any way into tricking the car computer into "believe" your ordinary F12 650 (my case) is a M6? Perhaps that opens options lacking for this and other M codes to work... Or maybe there's a VO code that would enable the M HUD? Someone with a M5 would be able to tell us whats in their config... Even better, someone with close relations with BMW, perhaps in south Carolina... Update Changed the production code to a m6, the FA cites the engine now as S63tu (I wish), nothing different in practice. Will drive the car and let you guys now if an extra 160 hp appears (ha ha). Perhaps additional parameters may allow some of the M functions
X5 5.0 MY12, M package, black sapphire 650i vert, MY12, Blue/ivory, to be modded soon... Gone: 997.2 modded, 987s (not forgotten ), MB C55 amg, Passat W8, Cayenne MY 08
I just tried it on my 650i F13 aswell.
I can get the HUD Options to appear, however the HUD seems to wait for me pressing the "M" button in Order to activate the M Hud. Is there any way to remap one of the existing buttons to do that? |
I have the same impression. If we could turn on the M button functions on idrive, would solve it but that particular command is not redundant. Perhaps a memory command on coding, similar to what we use to make the car "remember" to the AC settings or A.S.S. to turn on M mode everytime... If an M5 or M6 owner shows up in the forum, their code options could be copied, although it would be a LOT of work...
Any updates?
#25
The only way to get M-HUD is to have the M Instrument Cluster. End of story.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
