Clutch Help - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 06-04-2012, 12:14 AM
88320i 88320i is offline
Mein Auto: 1988 320i e30
Smile Clutch Help
Hey Guys
I have an 88 model e30 320i and i was just wondering if you can adjust the clutch cause my foot has to almost be fully off the clutch to get the friction point
Old 06-04-2012, 01:28 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Originally Posted by 88320i View Post
Hey Guys
The only clutch adjustment is the ride-height of the clutch pedal....you can adjust it to be level with the other pedals.
The pivot bolt that the master cylinder uses to connect with the pedal is an eccentric...you loosen the locking nut and rotate the bolt to get the right height.
Sounds like you may have to replace the clutch..... maybe a previous owner put some funny parts in there.
Old 06-05-2012, 11:00 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
Could also be a failing slave cylinder. I'd start off by bleeding the slave, then work from there
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
