Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 06-04-2012, 02:52 PM
steveawitt steveawitt is offline
Mein Auto: 1992 525i
Air Conditioner Mystery
1992 525i 120,000 miles
My Ac will not work and it really has me stumped.
I would appreciate any help.
Everything works, but it will not get cold.
New compressor
new expansion valve
new dryer.
I blew out all the tubes with air compressor when I had it apart.
put it back together pulled a vacume (no leaks)
added half a can of r134 , compressor kicks on, and low side shot up to 90 psi,...
high side 0.
shut compressor off and they equlize. this is odd?????
I don't understand why it only takes a half a can or 134 and the pressure shoots up so high??
If I run the compressor for a while at 40 psi on the low side, nothing gets cold.
I checked all the tubes nothing cold.
The ac button engages, ( blue dot on dial turned down) ,the condenser fan comes on, inside temp gage works, compressor kicks on, blower fan on.
If anybody has any ideas I could really use some help. thanks
Old 06-17-2012, 10:01 AM
Mystery Solved!
When I coverted the system to r134 i put the high side nipple on the low side, so I have been trying to charge the high side.
Swapped them out and it took a charge right away.
