Old 06-04-2012, 03:40 PM
abrookey abrookey is offline
Mein Auto: 2006 M5
valve cover gaskets
Ok, unless I missed something, I looked through wiki on what is involved changing valve cover gaskets on my 540 and didn't see anything. Intake gaskets, yes. Valve covers, no. Advice??
Old 06-04-2012, 05:39 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Search this site.
Old 06-05-2012, 12:55 PM
sainda210's Avatar
sainda210 sainda210 is offline
Mein Auto: 2001 BMW 540I 6spd
you'll need the valve cover gaskets and little rubber gromets for the bolts and also a little sealants to place on the 'U" shaped cutouts in the rear and also on the corners.
[SIGPIC]I want to go sideways all the time too...
Old 06-05-2012, 01:03 PM
jrcastro jrcastro is offline
Mein Auto: 1997 528i & 1999 540iA
Try these:
http://www.bimmerboard.com/forums/posts/124059
http://forum.roadfly.com/threads/131...t-(with-pics!)
Getting ready to do this on my 99 540i. Let me know how it goes.
Old 06-05-2012, 02:55 PM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
Originally Posted by jrcastro View Post
Try these:
Castro, I did mine over the winter. I highly recommend removing the fuel rail as it will make the job much easier. With the fuel rail off, you might as well do the intake gaskets. With the intake off , you may as well go ahead and do the valley pan job.
It's a vicious cycle.....
Old 06-07-2012, 02:43 PM
Damn! that does sound vicious make me not want to do it at all.
Old 06-07-2012, 03:24 PM
lucky540 lucky540 is offline
Mein Auto: 2000 540
just finished
I started my 540 project last month..worked a couple hours a day when possible as the 540 is third car..took my time and labled and took pics as i went along..started out as a simple gasket change behind the TB..Then ended up finding more and more leaks..I pulled out intake manifold and replaced all gaskets and rear CCV, replaced all vacum hoses from brake booster onward, valley pan, accumulater gaskets and two heater hoses coming off accumelater, water pipe o-rings, valve cover gaskets and grommets, both camshaft soleniod gaskets and new o-ring on sensor on lower rad hose....also got rims and valve covers powder coated ..It was not that bad of project, seemed like minimal tools were needed..Got hooked up on parts and powder coating..
total parts cost 338.79
powder coat rims and valve covers 130.00
Old 06-07-2012, 03:40 PM
RockChalk4Life RockChalk4Life is offline
Mein Auto: E39 540i/6, E36 4dr M3
I did valley pan, intake,throttle body, rear intake gasket and new ccv, water mani gaskeys, water pipe orings, hoses valve cover gaskets,and all the grommets, camshaft position sensors, it was all pretty easy, might as well do what you can while youre in there, trust me youll wish you did if you didnt. Aside from a metric socket set and wrenches the only extra tools I got were a pic set, 3/8" torque wrench and rubber mallet to knock the valve covers loose.
Sent from my SGH-T959 using Bimmer App
Old 06-08-2012, 06:25 AM
540indiana's Avatar
Castro, the term "vicious" may be a bit of overkill. It would just make sense to do all the work while you are there. I just have the valley pan, upper timing chain covers and vanos seals left to do.
Trust me , I wish I would have done everything when I did my VCGs.
Before I owned the 540, I was used to just doing general maintenance on my previous cars.
My first job on the 540 was the water pump and thermostat. I was scared to death to do the job . I just decided to "jump in with both feet" and do the job. 13 hours later ( Took that long as I was being very careful not to break anything) and fantastic support on this forum, I got the job done. The sense of satisfaction and accomplishment felt great. Not to mention all of the money I saved by not having the dealership or indy do the job.
At any giving point and time there is someone on here to provide assistance. If not , just search and you will find the solution.
Now stop and change your manpon.
Old 06-08-2012, 08:36 PM
MurrayP MurrayP is offline
Mein Auto: 98 540i
Valve Cover Gasket - the film
540Indiana I am surprised at how similar our experience has been. I bought my 98 540i last July and decided to dive in this Spring. Cooling a-z, valve cover gaskets (twice so far), plugs, CCV, etc.
Looking for a valve cover gasket DIY, I came accross this gem. Like I said, I have replaced and then had to reseal my VCG twice so far and now with this video I have a clear picture where I went wrong. I will now attempt this (thrice?)
Old 06-09-2012, 07:19 AM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: 01' 540 M-Sport, Scuderia
On a 540, one should seriously consider replacing the upper timing cover gaskets as well...another one of those "while you are in there" things...especially if they have not been change before, and/or if you see a bunch of oil and dirt on the front of your engine, and down below on the lower tray....that is where it is coming from.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 06-09-2012, 08:16 AM
avu3 avu3 is offline
Mein Auto: '02 540iA Sport
Mine started leaking within weeks of me doing the valve covers. I strongly encourage this course of action.
S
Old 06-25-2012, 01:49 PM
Mein Auto: 2006 M5
Try these:
Well, patience is sure the word for this, especially on the passenger side. I have to use my car every day so I didn't have time to do the intake etc.. I am used to the older big block Mopars, 20 minutes a side. Not this thing, but the leak is gone. Like mine, most leaks seem to be around the inner gasket, filling up spark plug holes and such...
Old 06-26-2012, 04:53 AM
collardgreens's Avatar
collardgreens collardgreens is offline
Mein Auto: 01 540/6
I would definetly change intake/throttle body and ccv gaskets as well as the valve cover gaskets and upper timing/vanos solenoid gaskets.
...Just not all at once. You can do the upper timing and valve covers at the same time. The intake gaskets can be done with the valve covers installed another time.
It takes more time ordering parts and research than it does to do the job. If its your first time anyway.
If you do everything at the same time and have a problem then you have to troubleshoot a lot more work.
Not sure if this has been posted but here is a great DIY for intake manifold.
http://www.bmw-planet.com/lib/BMW%20...kets%20DIY.pdf
Old 06-26-2012, 07:20 AM
Mein Auto: 2006 M5
Just looked over your attachment for the intake etc... Going to save this for the near future, all this enjoyment is coming soon. Thanks, looks like it could be a time saver
Old 06-26-2012, 07:47 AM
bigugly fab bigugly fab is offline
Dr.BMW
Mein Auto: 2015 M4
If the valve covers come off, replace the timing case cover gaskets.....
Old 06-26-2012, 01:47 PM
Yup, that is what post #11 and #12 said as well...
Old 06-26-2012, 02:08 PM
Mein Auto: 2006 M5
I agree, but as I said earlier, I use the car every day. Will need more time to do all that I want to do to it
Old 06-26-2012, 04:11 PM
Dr.BMW
Mein Auto: 2015 M4
just trying to hammer home the message
why do a job twice?
if you have the time to do it twice, you have the job to do it once RIGHT.
Old 06-26-2012, 04:51 PM
Mein Auto: 2006 M5
why do a job twice?
Ok, had to pause for a moment, the "do a job twice - and right" really ******* me off. Let me repeat, I can not let the car set a whole day no matter what, it is a daily driver, I have no choice in the matter, no second car to use. As for doing things "right" I am an NHRA record holder with a big block HemiCuda, I know what I am doing, and how to do things right, but seriously my friend, it is a time thing. Patience is now my middle name, x wife got everything else
Old 06-26-2012, 06:15 PM
dms540i's Avatar
dms540i dms540i is offline
Mein Auto: 1999 BMW 540iA
Do it all at once, the valve cover gaskets, timing chain gaskets and CCV. Unless you want to go right back in there and do it again, and again.
BMWCCA#401441
Old 06-26-2012, 07:11 PM
Dr.BMW
Mein Auto: 2015 M4
why would it make you mad? its truth brother. you WILL end up doing them again to do the timing case covers (which are a ROYAL pain to do without pulling the valve covers off fully), so why put the effort into the job, in the first place?
- if thats the case, go drop it off to have someone do it for you, and get a rental for the day.
I personally can do timing case covers and valve covers on an M62/M62tu in less than 3 hours..... but to each their own.
Its really the moons the back of the heads, the corners in the back, an the "T" joint where the timing case/head/valve cover come together is where the heavy leaks come from. the timing case gaskets get soooooo hard, you have to chip them out with a screwdriver, and they come out in 1/2" chunks sometimes.....
Old 08-13-2012, 04:00 PM
speedchase speedchase is offline
Mein Auto: 2001 540i MT M62
Somewhat related to this topic. I changed the spark plugs on my 2001 540i and noticed oil (with varying levels) on 5 out of 8 spark plug holes. Not knowing the implications, I pulled out the old spark plugs without cleaning out the oil in those holes and let some oil in each of those flooded spark plug holes. The obvious thing happened when I started the car after all the spark plug replacements; white smoke for less than a minute but the car runs great now since the old plugs (Bosch) were really beaten out.
The question is - How bad have I messed up the engine by letting the engine oil burn in the cylinders and, also, have I messed up the plugs warranting a replacement (if not very soon).
Please advise and let me help sleep better without the anxiety of having done a miserable job replacing plugs. I am a newbie but every day learning new things about E39 maintenance. I am going the DIY route since in the past 3 years, I have spent close 3k for steering fluid pump replacement (including all the belts), axle replacement & CCV replacement (this is the one I got fleeced most for close to 1k by an Indy).
2001 540i MT - Still a newbie until I change my VCG, VANOS & Coolant system...
Repairs so far - Steering fluid pump ($1k - Indy), CCV replacement ($1k hosed to another Indy) & Axle replacement ($850 to another indy).. 3 indys to date and now I am diving all in as a DIY'er
Old 08-13-2012, 06:03 PM
Mein Auto: 01 540/6
I could be wrong but I don't think a little oil will hurt.
But it's not doing any good either,
You will soon experience whatever ailments your old plugs had as the oil keeps leaking.
Your inner valve cover gasket is leaking letting oil seep into the plug wells.
You should clean before you remove your old plugs, a vacuum with a straw taped to it or something. You don't want any foreign material falling in those ports.
Old 08-13-2012, 08:05 PM
Dr.BMW
Mein Auto: 2015 M4
i would not, unless you intend to replace the orings on the injectors.
