E46 (1999 - 2006)
Old 06-05-2012, 12:44 AM
PerfectStorm01 PerfectStorm01 is offline
Mein Auto: 2001 320Ci
Question Coming to a stop idle drop
Hey everyone, I've been doing lots of research on this and I was hoping others could share their experience/fix if they had similar idle issues.
I've been battling this issue for a while now and I thought I had it figured out when I cleaned my MAF, ICV and DISA four months back, but it has resurfaced again. While coming to a full stop my idle seems to dip to around 475-500 rpms as the car comes to a rest. The car sort of shakes slightly like it's about to stall, but it never does. The idle then quickly returns to its normal 550 rpm as though it's correcting itself. It happens maybe 50% of the time depending how I'm stopping .
There could be lots of reasons for this, but this is what I am doing immediately: 1)replacing intake boot; 2)replacing intake camshaft position sensor; and 3) fuel filter. A bit further down the road I will drain and replace tranny filter and replace DISA (I believe the gasket is shot).
My CEL/SES has never come on and the car runs great otherwise. No codes. 2001 Auto, 320Ci, 94K miles. As far as PM: cooling system overhaul, new belts, tensioners, PS pump, alternator and spark plugs.
Has anyone else experienced this? If so, have you fixed it and how? So far, I'm just hitting the normal wear and tear items so I don't mind doing it without knowing if it will fix my problem or not.
Old 06-05-2012, 01:15 AM
LaCrosse540i6's Avatar
LaCrosse540i6 LaCrosse540i6 is online now
Smiling from gear to gear
Mein Auto: '03 540i M-sport
I'm dealing with this same issue, except mine will stall sometimes. I've replaced both intake boots, CCV and hoses, vanos seals, VC gasket, spark plugs, fuel filter, cleaned MAF, throttle body, and the ICV.
I also "upgraded" my DISA valve with the G.A.S. kit, but I'm starting to wonder if I should just replace the unit all together.
No codes here either.
Old 06-05-2012, 01:45 AM
Have you changed the intake CPS yet? I can't remember were I read it, but I think it was on e46fanatics where the guy changed everything you did including the intake cps and it fixed it. Let me see if I can find that thread again. This is a pain in the A$$. Have you checked your vacuum hoses as well?
Old 06-05-2012, 11:12 AM
eleison eleison is offline
Mein Auto: 330i
My car was stalling 20% of the time last year during the summer (if I didn't want it to stall I would have to apply more gas OR make sure it was always in gear) -- this was after replacing the MAF, intake boot, hoses vanos seals, VC gasket, spark plugs, fuel filter, CPS, oxygen sensors, blahah... blahha.. blahha . (yeah, it was frustating
However, after I fixed the rattling from the heat shield under my car the car is acting more civil -- I think the heat shield that was rattling like a can full of pebbles might have been affecting my exhaust system and causing the unstable RPM at idle. It was banging against the exhaust components and probably causing the sensors to read incorrectly. I could be wrong though. I've only fixed the rattle of my car a month or two ago -- but no stalls yet and it seems more stable :-)
Old 06-05-2012, 11:51 PM
I have not changed the CPS yet, but I suppose that's another one I should check off. I have replaced the SAP and FPR vacuum line.
eleison, that's an interesting idea you brought up. I suppose if something was rattling that could be picked up by the knock sensor.
Old 06-06-2012, 09:03 PM
hey lacrosse, check out this thread from e46fanatics regarding another possible vacuum weak point.
http://forum.e46fanatics.com/showthread.php?t=921500
Old 06-06-2012, 10:37 PM
Ahh, so that's where that cap is. I had heard about that being a potential problem, but I never got around to checking it.
I'll probably regret saying this, but I really wish my car would just throw a code.
Old 06-06-2012, 10:51 PM
I hear ya! I just added it to the list of things to check.
Old 06-07-2012, 12:36 AM
Post #5 http://forum.e46fanatics.com/showthread.php?t=885693
Looks like this guy has resolved a similar issue with a new CPS. I'll put that next on my list and report back.
Old 06-07-2012, 01:19 AM
Good luck! I'm still looking for a different post I saw regarding the same issue we have. I knew I should have subscribed to it back then...damn
Old 03-02-2016, 07:09 AM
dimontas dimontas is offline
Mein Auto: BMW e46 2003
Hey, was there a solution for the problem above?
I am battling this for over a year already and am at the stage where I already consider selling
Old 03-02-2016, 10:55 AM
smithpatrick smithpatrick is offline
Mein Auto: 01 325i, 1990 325i, 320i
vacuum pressure
Hey guys;
When you remove your oil fill cap, with the engine running. What is the reaction?
When you place you hand on the oil fill hole, How much pressure do you feel?
I was able to increase my vacuum pressure, with positive results. 2001 325i
4 BMW Motorcycles R75/5, 2 R60/6, and a R90/6
5 E30's 84, 87, 3 90's
3 E36's 95 euro 320, 98 323is, and 99 328is
2 E46's 2001 325i manual, 2000 323i auto
Old 03-05-2016, 09:02 AM
seagates seagates is offline
Mein Auto: 530I
Same problem here, but I think mines related to the tcc solenoid...I did the oil cap test and there was a slight audible idle change but the suction is good
Subscribe and follow http://thetotalauto.com
fuel filter, idle, intake boot, intake cps
