Old 06-05-2012, 01:13 AM
ImSW1 ImSW1 is offline
Mein Auto: F10
TPMS PSI/Temp Data - Working or Not
I've added a spreadsheet to this post with all the data to date. Just remove the .pdf extension and you'll be able to open in Excel. So far I can't pinpoint any specific pattern.
All right folks. Attempting to track down why TPMS reads PSI and temp for some vehicles and not for others. HU_CIC, 3001 Ex Box, "rdc_safety" set to aktiv. If you set HU_CIC, 3001 Ex Box, "rdc" to nicht_aktiv it will remove the TPMS menu from the iDrive but you will still see green tires on the screen. Last note: Before the software update (Global) I couldn't get the PSI or temp labels to show. After the update I now get the labels but no readings.
Continuing from original coding thread:
Here's the data we've been collecting. Just reply to this post with the following details:
Model:
Build Date:
Delivery Date:
Status: Working/Not Working
Did you ever change the wheels and/or tires:
TPMS Type:
Tires:
Air/Nitrogen/Other: Regular plain ole air
I'm posting the answers I can find from the original thread.
Username: Ausfahrt:
Model: 2011 550i
Build Date: July 2011
Delivery Date 29 Sept 2011
Status: Working
Did you ever change the tires: YES
TPMS:BMW5 R12 KIT BMW TPMS Sensor Kit 5 Series 2011 from BavarianX
Tires: TOYO PROXES T1R
Air: Regular plain ole air
Username: shawnsheridan
Model: 2011 535i M-Sport
Build Date: 10/2010
Status: WORKING
Did you ever change the tires: Yes
Tires changed by Ind Shop/Dealer: Dealer
Tires: Michelin Pilot Super Sport (same size as OEM non RFT)
Air: Normal Air
Username: alex_c
No, I have not changed my tires at all!
I have the OEM tires with the original metal stem valves.
Model: 2012 535
Built: 8/25/2011
Status: Not working
Tires: Original RFT
gas: Nitrogen
Username: Stealth.Pilot
Model: 2012 550i
Build Date: Sep 30, 2011
Delivery Date: Oct 17th
Status: NOT WORKING
Tires changed by Ind Shop/Dealer: Ind Shop
Air: Normal Air
Username: Jeg23
Model: 2011 550I
Build Date:Jun 29th 2011
Delivery Date July 27th
Status: TPMS Working
DID you ever change the tires: Yes or NO
Tires: RFT (OEM) or Regular Tires?
Air: Nitrogen or regular or Dont know
Username: ImSW1
Model: 2011 528i
Build Date: Jul 10
Delivery Date Aug 10
Status: Not Working
Tires: RFT (OEM) or Regular Tires? Regular Tires
TPMS: Replaced Beru RDE 0008
Air/Nitrogen/Other: Air
I'd like to really like to hear from pre 09/10 owners with the earlier TPMS units. I know we have a few post 09/10 owners that the readings aren't registering, so I want to know if it's working in any pre 09/10 builds.
Sean
Old 06-05-2012, 01:19 AM
wdimagineer's Avatar
wdimagineer wdimagineer is offline
Mein Auto: 2013 M5
I'll add myself here... works with both sets of wheels.
Model: 550xi
Build Date: 1/2012
Delivery Date: 3/2012
Status: Working
Did you ever change the wheels and/or tires: Yes, works on both
TPMS Type: OEM, metal valve stem
Tires: Goodyear LS2 / Michelin Pilot Super Sport
Current: 2014 X5 xDrive50i ZMM - Alpine White/Mocha (Mods In Progress!)
Past: 2014 Jeep SRT - 2013 Tesla Model S P85+ - Bimmerpost Featured 2013 F10 M5 - 2012 550 xDrive - 2011 M3 ZCP
Old 06-05-2012, 07:31 AM
alextremo alextremo is offline
Mein Auto: F10 550i
Model: 550i
Build Date: 12/2010
Delivery Date: 2/2011
Status: Working
Did you ever change the wheels and/or tires: Yes, but OEM wheels/TPMS are on the car now (haven't tested with the aftermarket winter wheels/TPMS yet)
TPMS Type: OEM
Tires: Michelin
Air/Nitrogen/Other: air
Old 06-05-2012, 08:58 AM
Chuck W.'s Avatar
Chuck W. Chuck W. is offline
Mein Auto: 12 BMW 535I MS Alpine Wht
I have it and it works. What I noticed is that at times when you first start out cold in the morning it takes a minute or two for the info to come up. If the car has been driven it comes up immediately.
Model: 2012 535I MS
Build Date: 11/2011
Delivery Date: 12/3/2011
Status: Working
Tires: Michelin Non-RFT
Air: Plain Air
2016 BMW M2 - ED Pick Up on 07/12/2016; US Pick Up on 09/22/2016
2012 BMW 535I - ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012
2001 Boxster S 29,000 Miles, Original Owner
2007 Mini Cooper S - Sold
1997 Porsche 993 Turbo – Sold
1997 Porsche 993 Cab - Sold
Old 06-05-2012, 09:50 AM
nicewonky nicewonky is offline
Mein Auto: 2012 535i xDrive
Similar to above, no reading on start but it populates pretty quickly (within a few minutes)
Model: 2012 535xi (non-sport so 18")
Build Date: 11/2011
Delivery Date: 12/4/2011
Status: Working
Did you ever change the tires: No
Tires: Goodyear RFT 18"
Air: Plain Air
Old 06-05-2012, 02:10 PM
dmunz dmunz is offline
Mein Auto: 535i GT
Shawn coded mine last Sunday in Houston. I see the indicators on the display but don't get data (just an underline). I can also see the units in settings and make changes to them. That is, I can change from psi to bar and is shows up on the display, but still no data.
Model: F07 (535i GT)
Build Date: 12/11 (MY 2012)
Delivery Date: 4/21/12
Status: Working/Not Working: Not Working
Did you ever change the wheels and/or tires: Nope
TPMS Type: OEM metal valve stem
Tires: Dunlop DSST
Air/Nitrogen/Other: N2 (according to the valve stems that came with the car...)
FWIW
DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g.
Old 06-05-2012, 03:19 PM
clutchlee clutchlee is offline
Mein Auto: BMW
Works for me fine.
Model: 2011 535i xDrive (Sport Package)
Build Date: 03/2011
Delivery Date: 5/31/11
Status: Working
Did you ever change the tires: Yes, only front (GY Run-flats to Continental)
Tires: Continental (front); GY RFT(Rear)
Air: Plain Air
Old 06-07-2012, 10:14 AM
Griffin 27 Griffin 27 is offline
Verified Trusted User
Mein Auto: 2012 535i, Space Grey
Model: 2012 535
Build Date: 03/2012
Delivery Date: 5/11/2012
Status: Not Working
Tires: OEM 19" M Sport, OEM Dunlop tires
Air: Plain Air
2012 535i, April build, Space Grey, Oyster Interior, 19" M sport rims/tires, premium pkg, premium sound, side/top cameras, heated seats, comfort access, ceramic controls, OEM spoiler, painted front reflectors, 35% tint, rear Fog lights, coded to my liking.
Old 06-07-2012, 10:33 AM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: F10 M5
Model: 2012 535 IX m sport , 2012 535 I , 2012 535 I m sport
Status. : working
Never changed the tires.
Old 06-07-2012, 12:01 PM
RO-CK RO-CK is offline
Mein Auto: 2012 X3 F25 20dX WY31
Maybe this is a dumb theory, but would it be possible that this particular feature working and the Sports Display (HP/Torque meter) in some cases and others not, may have some kind of relation with the fact that they don't have the CIC/Navigation Professional and only have the BMW Business system installed?
By the way, thanks @Dreamcar, Sean, Shawn and all that contributed for all this.. My E-net cable arrives Saturday!! Finally
Old 06-07-2012, 12:40 PM
grilodan grilodan is offline
Mein Auto: F80 BMW M3
Username: grilodan
Model: 2011 535i
Build Date: 08/2010
Status: NOT WORKING
Tires changed by Ind Shop/Dealer: N/A
Tires: Goodyear OEM
Air: Normal Air
- 2015 M3 (Born 08/14) - Black Sapphire /Black Full Merino /Carbon Fiber - ZDB/ZEC/ZLP/2MK/2VF/2VZ
- 2013 X5 35i Sport (Born 08/12) - Titanium Silver /Oyster Nevada /Dark Bamboo - ZCV/ZCW/ZPS/ZAP/2VA/610/7XA/456
- 2013 X1 28i (Born 11/12) - Alpine White /Beige Dakota (Sold 09/14)
- 2011 535i (Born 08/10) - Titanium Silver /Black Dakota (Sold 08/12)
- 2010 335i (Born 02/10) - Titanium Silver /Black Dakota (Sold 09/10)
- 2007 328i (Born 07/07) - Jet Black /Black Dakota (Sold 04/10)
Old 06-07-2012, 07:53 PM
Mein Auto: 535i GT
Has anyone looked for or found the code to turn the rotational monitoring code off? I wonder if that (RPS??? I think) might be on and interfearing.
I'll try to poke around tomorrow if I get some time in my car to look at the code.
FWIW
DLM
Old 06-07-2012, 07:57 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
@dmunz:
FYI. TPMS is Reifen Druck Control, aka RDC, and FTMS is Reifen Pannen Anzeige, aka RPA.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 06-08-2012, 07:01 AM
Mein Auto: F10
No great breakthroughs so far.
Last night I activated FTMS. The RPA choice is just above the RDC FDL line (not RDC_SAFETY). It was set to nicht_aktiv, I changed it to aktiv. I now have an RPA ecu choice on my CAFD which has so many settings it's ridiculous. I was going through it, but just didn't have the time to delve deep into the tree.
I also adjusted two FDLs sitting in KOMBI that related to RDC, but my suspicion is that they are the FDLs that allow TPMS error codes to display on the guage cluster. Aktiv to Nicht_Aktiv.
This morning I started the car and reset the TPMS then drove away. Previously my TPMS display showed the pressure and temp icons (and green tires) but didn't give me anything else. I didn't get the dashes like many of you get. So after driving for about 200 ft I got the same display but with dashes now.
I'm going to change the RPA/KOMBI settings back to their original values one-by-one this afternoon to see what happens. Then I report back my findings.
Sean
Old 06-08-2012, 07:21 AM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
I am happy to see you back on coding!
Old 06-08-2012, 09:22 AM
Stealth.Pilot's Avatar
Stealth.Pilot Stealth.Pilot is offline
The Driver
Mein Auto: 2014 M5
Thanks for pushing on this Sean. I hope we can crack it.
Update on my situation is I had the dealer check the TPMS and valve stems in case the tire shop messed with them. They said I have the original OEM TPMS and metal valve stems.
2014 Porsche 911 Turbo S
2015 Mercedes C300 4MATIC
Memberships: BMW CCA, Peachstate PCA, NMA, AAA, RAC
Sold:
2015 Jaguar F-Type R
2014 BMW M5 Individual Dinan Stage 1
2013 BMW M5 Individual
2012 BMW 550i Dinan Stage 2
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 06-08-2012, 02:22 PM
miotoo miotoo is offline
Mein Auto: F10 520d
Did everybody check this value in ICM ? 2VB is the SA code for Tire Pressure Monitor.
Old 06-08-2012, 02:23 PM
2VB is standard equipment in the U.S.
Old 06-13-2012, 09:29 PM
I know this is a long shot, but I am going to ask anyway. For those without working TPMS, is your car also equipped with Active Steering?
Old 06-13-2012, 10:03 PM
The Driver
Mein Auto: 2014 M5
Yes
Sold:
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 06-13-2012, 10:51 PM
No active steering on mine.
Old 06-14-2012, 03:18 AM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
If Alex also has active steering then you may be on to something as stealth also has active steering.
Edit: Just checked he doesnt have active steering... But i am curious why did you think active steering is the cause?
Old 06-14-2012, 07:34 AM
Mein Auto: 535i GT
No active steering on my F07 either.
FWIW
DLM
Old 06-14-2012, 07:39 AM
JEG23 JEG23 is offline
Mein Auto: 550i
@shawnsheridan,
I have active steering and my TPMS is working fine.
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 06-14-2012, 07:41 AM
Mein Auto: 535i GT
How is the data sent?
Are the sensors using Bluetooth? It might be possible to sniff out the signal and see what is being fed back to the system in the car.
FWIW
DLM
