Old 06-14-2012, 06:44 AM
JEG23 JEG23 is offline
Mein Auto: 550i
Originally Posted by miotoo View Post
Did everybody check this value in ICM ? 2VB is the SA code for Tire Pressure Monitor.
@shawnsheridan,
Did you check this value quoted earlier by Miotoo ? In my car it is set to verbaut.
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 06-14-2012, 07:18 AM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: Future: F80 M3
Old 06-14-2012, 03:54 PM
aosman aosman is offline
Mein Auto: 2012 F10 550i
Originally Posted by shawnsheridan View Post
I know this is a long shot, but I am going to ask anyway. For those without working TPMS, is your car also equipped with Active Steering?
No AS on mine
2012 550i M Sport
Old 06-14-2012, 04:06 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Originally Posted by DreamCar View Post
If Alex also has active steering then you may be on to something as stealth also has active steering.
Edit: Just checked he doesnt have active steering... But i am curious why did you think active steering is the cause?
Only because I coded a car last night with IAS, and TPMS did not work, and I noticed the Tire Chain mode in the CIC to switch off IAS, so I thought there may be some connection. Obviously that is not the case.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 06-14-2012, 04:11 PM
Originally Posted by JEG23 View Post
@shawnsheridan,
JEG23
No, not specifically. As I previously wrote, 2VB is standard equipment in the US. Thus 2VB should be on the VO, and in turn CAF / 3000 / IcmKod_B_SA2VB should by default be set to verbaut (installed).
I would also think if this was turned off, TPMS would not work at all as opposed to working, albeit without PSI and Temp.
- BMWCCA #446923
- flick
Old 06-14-2012, 08:13 PM
mjgood mjgood is offline
Mein Auto: 2011 550i M-Sport
kind of a tangent on this subject....
If the tires are rotated how does the car know which is which.... are the sensors coded specifically and have to be removed and relocated, or is there a proximity receiver near each tire?
2011 550i M-Sport
2011 Countryman S
Bell 407
Old 06-14-2012, 10:15 PM
I am pretty sure BMW uses a High Line Direct TPMS, which has an LF Antenna in each wheel well that reads the RF signal transmitted from each tire sensor, which includes an identification signal for localization (wheel location).
- BMWCCA #446923
- flick
Old 06-15-2012, 05:39 AM
Thanks Shawn...
2011 550i M-Sport
2011 Countryman S
Bell 407
Old 06-15-2012, 04:47 PM
FastMarkA FastMarkA is offline
Mein Auto: 2008 535xi
Model: 535 xDrive w/ Sport Package (not M-Sport)
Build Date: 03/2011
Delivery Date: 04/2011 (Munich); 05/2011 (Chicago)
Status: Working
Did you ever change the wheels and/or tires: Had the crappy All-Seasons replaced w/ Dunlop Summers
TPMS Type: Metal Caps
Tires: Dunlop Sport Maxx 19s
Air/Nitrogen/Other: Pretty sure it's plain ole air
2008 535xi 6-speed - Blk Sapphire, ---2011 535xi - Jet Blk, Blk Dakota,
Blk Dakota, Bamboo Prem | Cold Wthr -- Aluminum | Prem | Prem 2 | Cold Wthr
Sport | iPod/USB | Nav | Sat --- -------Sport | Sport Auto | Fold Down Seats
Fold Down Seats | Htd Rear Seats -- ---Side/Top Cameras
PDC | 18" wheels | Logic7
(Good riddance!)
Old 06-18-2012, 04:35 PM
dmunz dmunz is online now
Mein Auto: 535i GT
pzdata version compatability?
Here's a new thought on this - could it be linked to the version of pzdata we are using? Shawn coded mine with 46.3 (I think) and mine does not work. 1StBimmer, who also has an F07, coded his with 45.X (again, I think) and his works.
I don't know what the difference in the files is, but if you have not been able to get pressure and temp data, which version of the pzdata files are you using?
FWIW
DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g.
Old 06-18-2012, 04:49 PM
grilodan grilodan is offline
Mein Auto: E70 X5 35i Sport Activity
Mine is 46.3. Doesn't work.
- 2013 X5 35i Sport Activity (Born 08/12) - Titanium Silver /Oyster Nevada /Dark Bamboo - ZCV /ZCW /ZPS /Sport Package /Adaptive Drive /Soft-Close Doors/Running Boards /HUD /Shift Paddles /Comfort Seats /6NR /6NF
- 2011 535i (Born 08/10) - Titanium Silver /Black Dakota /Anthracite - ZCV /ZCW /ZPP /ZP2 /6FL /6NF (Sold 08/12)
- 2010 335i (Born 02/10) - Titanium Silver /Black Dakota - ZCW /ZPP /6FL (Sold 09/10)
- 2007 328i (Born 07/07) - Jet Black /Black Dakota - ZSP /ZPP /6FL (Sold 04/10)
Old 06-18-2012, 04:52 PM
FWIW
DLM
I don't think the PSDZdata version matters, as when FDL Coding, it does not apply that Integration Level to the module. While you are using the latest ISTA/P files, you are still only changing a parameter on the existing module's software. If it is a software issue and not hardware related, what is more likely is that the issue is what software level is the actual module on based on when it's firmware was last flashed. Since I have successfully coded some cars with v46.3, v46.3 by itself simply can't be the issue.
- BMWCCA #446923
- flick
Old 06-18-2012, 05:42 PM
DreamCar's Avatar
Moderator
FWIW
DLM
I think i coded around 14 cars with 46.3 data files and only one car had problem... Worked fine in all the other cars
Old 06-18-2012, 06:51 PM
Mein Auto: 535i GT
I knew it was a longshot. I'm just frustrated that it doesn't work for me. This, the sport display and the folding mirrors were the big things on my "why I want to code" list.
FWIW
DLM
Old 06-18-2012, 06:53 PM
FWIW
DLM
I know, it's frustrating to me too. I need someone who has a car like yours not working, then have the dealer bring the vehicle software current, and the try coding it again to see if it is the ISTA/P version on the car.
- BMWCCA #446923
- flick
Old 06-20-2012, 12:38 PM
Mein Auto: 535i GT
On a lark I changed this to nikt today at lunch to see if it would make a difference. I'm still not getting temp or pressure numbers. I do get the green highlites on the tires but I don't get the TMP Active text at the bottom of the display.
I'll go turn it on later today and see if it rests anything.
FWIW
DLM
Old 06-22-2012, 08:09 AM
chinese_food chinese_food is offline
Mein Auto: F10
Model:528i
Build Date: july 2011
Delivery Date: september 2011
Status: Working
Did you ever change the wheels and/or tires: no
TPMS Type:?
Tires: 275/55R17
Air/Nitrogen/Other: Nitrogen
Old 06-26-2012, 07:52 PM
Hey guys ... anyone out there still trying to figure this out? I've tried all I could, but nothing yet.
Old 06-26-2012, 09:48 PM
What ISTA/P version is on your car?
- BMWCCA #446923
- flick
Old 06-27-2012, 12:27 PM
Here it is.
Old 06-27-2012, 01:44 PM
Here it is.
Ok...seeing you have have the latest software, there goes my "Old ISTA/P" theory. I'm at a total loss as to why.
- BMWCCA #446923
- flick
Old 06-27-2012, 02:55 PM
Had a feeling you'd say that. I wonder if lack of Sport Auto or Sport Package have anything to do with it. Or maybe it's just definitely a pre 09/10 thing. I can't imagine that BMW would have different TPM sensors between non-sport and sport, but who knows?
Old 06-27-2012, 03:18 PM
Stealth.Pilot's Avatar
Stealth.Pilot Stealth.Pilot is offline
The Driver
Mein Auto: 2013 M5
It's not that. DC and I both have M Sports with Sport Auto.
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP
Old 06-27-2012, 03:19 PM
If I am not mistaken, the problem has randomly affected both pre and post 09/10 builds and Sport/Non-Sport models. There has been no identifiable common denominator for the problem.
- BMWCCA #446923
- flick
Old 06-27-2012, 03:41 PM
wchjr56 wchjr56 is offline
Mein Auto: 535ix
Model:535i
Build Date: May 2012
Delivery Date: May 2012
Status: Working
TPMS Type:?
Tires: RF All seasons
Air/Nitrogen/Other: Assumed Air
