BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#101
And it seems to have taken, I've been in and out of the car all day and the data still displays. FWIW DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g. |
#102
Although it just occured to me that I have changed phones. My BlackBerry pooped out and I'm using a new iPhone. I have not bothered to set up the BT connection. I wonder if there was interfeerance with the signals. I think the BT still works on my BB maybe I'll give that a try tomorrow... FWIW DLM
#103
So I guess the sensors just need a good thump to get them to behave. FWIW DLM
#104
Well,I guess one must now try the curb bumping approach to see if that is what will make it work!
I wish I could get mine to work... I was looking for additional parts to receive the TPMS data, which I think is what Shawn was saying my car is missing - but I cant find a good way to confirm approach/parts list needed to make it work; After my last experience with the retrofit of the DVD changer (which is now 4 weeks and I still don't have my car back) no sure I want to try adding parts again! oddly; the issues were with the latest Integration level and causing codes in stuff like side view camera's etc and not the DVD changer project itself... If anyone has done the TPMS upgrade and had to add the receiver and recode the car, I would love to hear how it was done :-) |
#105
Model: 2013 550i
Build Date: 11-13 Delivery Date:12-20 Status: Working Did you ever change the wheels and/or tires: No TPMS Type: TPMS Tires: Dunlop Sport Maxx Air/Nitrogen/Other: air Figured this would be the best thread to ask this question.. How do you turn the whole TPMS off?? I was coding my friends '12 750Li active hybrid and he switched out wheels on the car but doesn't want to switch out the sensors. He wants to get rid of the warning in iDrive and on the dash, I tried turning RDC from aktiv to nicht_aktiv and it did not effect the warning. Any input is appreciated. Thanks! |
#106
Read this: http://www.bimmerfest.com/forums/sho...highlight=fuse
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#107
Anybody have any advice on what to try next?
2012 550i | M Sport | Space Gray | Black Dakota | Anthracite | Ceramic | Sport Trans | ARS | HUD | Convenience | Cold Weather | Luxury Seating | Premium Sound Prior 2008 STS-V ( retired ) 2004 CTS-V ( retired ) |
#108
However, if you insist on verifying it, use the Search Box in E-Sys, and look in your ICM ECU for "2VB", and see if you can find IcmKod_B_SA2VB or something similar to it. The Search Box only searches from Top to Bottom, so make sure you start at the very beginning of the CAFD. You should reset TPMS and drive the car afterwards before the Pressure Temp appears where the 3 dashes are. If it still does not work, then, and for reasons unknown, your are one of the unfortunate few that it just won't work for.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 01-25-2013 at 05:51 PM. |
#109
Yeah this is a hit or miss with each car...Some work right off the bat and some dont work for crap..Its like cracker jack box...Dont know until you open up the box to see the prize you got!
![]() Coding Inquiry call 917-939-4980
#110
Unfortunately it's still not working for me. When I first start the car it says the following in a gray bar across the bottom of the screen.
"Status: Tire pressure and temperature measurement..." Any way to see that the rest of that status message is? I'm assuming it's something like "Tire pressure and temperature measurement system initializing" but I would still like see the full status message. Also, is the pressure and temperature display a standard / supported option on European cars? If so, maybe we can find a European troubleshooting guide that will tell us what to check when a sensor isn't reporting pressure and temperature.
#111
#112
Does anyone know of a way to see the rest of that status message? Also, What are the components of the TPM system? Just wondering if the part that receives the signal from the sensor in the tire needs to be programmed to listen for both psi and temp.
#113
#114
Was the mystery ever solved?
2011 535i 2013 VW Golf TDI |
#115
I don't think so, although it has been a very long time since I have seen or heard of a 2VB equipped car where it has not worked.
#116
In June 2012 I had the global update done and promptly took the car back to Chase to have everything recoded. When he attempted to activate the TPMS Data we got the dreaded "---". Yesterday Chase added some coding to my car and I brought the info from Post 72; ICM: IcmKod_B_SA2VB = verbaut CIC: RPA_CIC = nicht_aktiv RDC = aktiv RDC_SAFETY = aktiv The CIC is set up correctly from our last attempt. We couldn't find the ICM part though. Is it hidden anywhere special. We found two ICM modules and there were no "IcmKod_B_SA2VB" in there. Suggestions? TIA.
2012 BMW 535I 14K Miles ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012 Alpine White, M Sport, Blk Nappa, Cold Weather, Luxury Seating, Premium, Premium Sound, Tech, Sports Trans, Active Cruise, Heads-Up Mods - Quad Exhaust Tips, HID Fog Lights, Clear Front Reflectors, M5 Spoiler, Calipers Painted Black, 12.5 mm Rear Wheel Spacers, 5% Tint Rear - 35% Tint Front - 50% Tint Windshield Coding by itschase (Chase) Next; ED of 2014 M4 Last edited by Chuck W.; 02-28-2013 at 07:58 AM. |
#117
CAF [ICMQL] 3000 Daten, F8 Funktionen IcmKod_B_SA2VB = verbaut
#118
Good deal. Thanks.
2012 BMW 535I 14K Miles ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012 Alpine White, M Sport, Blk Nappa, Cold Weather, Luxury Seating, Premium, Premium Sound, Tech, Sports Trans, Active Cruise, Heads-Up Mods - Quad Exhaust Tips, HID Fog Lights, Clear Front Reflectors, M5 Spoiler, Calipers Painted Black, 12.5 mm Rear Wheel Spacers, 5% Tint Rear - 35% Tint Front - 50% Tint Windshield Coding by itschase (Chase) Next; ED of 2014 M4 |
#119
Chuck -
Were you able to get your TPMS back? I just had dreamcar reprogram my car (after it was updated by my dealer a month ago). Dreamcar programmed me in the spring of 2012, and TPMS worked, we couldn't get it going this time around. Aceman
2012 550iX Alpine White, M-Sport, CW PKG, SAT, HUD, PREM SOUND, SUR VIEW CAMERAS Mods: OEM Spoiler, 35% tint, Front/Rear Mud guards |
#120
No. itschase (Chase) has tried twice now without success. The ICM_QL [1c] CAFD as follows: CAF [ICMQL] 3000 Daten, F8 Funktionen IcmKod_B_SA2VB = verbaut as Shawn recommended is no where to be found. I guessing the Global Update added something or took away something that prevents us from recovering the TPMS PSI & Temp Data.
2012 BMW 535I 14K Miles ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012 Alpine White, M Sport, Blk Nappa, Cold Weather, Luxury Seating, Premium, Premium Sound, Tech, Sports Trans, Active Cruise, Heads-Up Mods - Quad Exhaust Tips, HID Fog Lights, Clear Front Reflectors, M5 Spoiler, Calipers Painted Black, 12.5 mm Rear Wheel Spacers, 5% Tint Rear - 35% Tint Front - 50% Tint Windshield Coding by itschase (Chase) Next; ED of 2014 M4 Last edited by Chuck W.; 03-02-2013 at 06:08 PM. |
#121
What ISTA/P is on these cars? 48.3 or the new 49.0?
#123
he got his car flashed like 5 weeks back. do you think the dealers already have access to 49? i didn't pay attention to the i level, even though he asked me about it.. Lazy me. I think i saw 503 at the end in the i level. any ways will ask him to export the profile again. |
#124
I am pretty confident you already have this. when did you get your car flashed? |
#125
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
