Old 03-03-2013, 05:45 AM
Chuck W.'s Avatar
Chuck W. Chuck W. is offline
Mein Auto: 12 BMW 535I MS Alpine Wht
Originally Posted by shawnsheridan View Post
What ISTA/P is on these cars? 48.3 or the new 49.0?
Because mine was done in June of 2012, I am guessing 48.3.
Originally Posted by DreamCar View Post
looks like there are two modules starting with ICM even i got confused initially as i was looking for it in a wrong module.
I am pretty confident you already have this.
when did you get your car flashed?
Yes, Chase checked both modules. The Global Update was done in June of 2012.
2016 BMW M2 - ED Pick Up on 07/12/2016; US Pick Up on 09/22/2016
2012 BMW 535I - ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012
2001 Boxster S 30,000 Miles, Original Owner
2007 Mini Cooper S - Sold
1997 Porsche 993 Turbo Sold
1997 Porsche 993 Cab - Sold
Old 03-03-2013, 02:06 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Strange. If you can, post the CAFD names for both ICM ECU's.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 03-03-2013, 06:27 PM
Chuck W.'s Avatar
Chase is out of town. I'll get it as soon as we can meet up.
Old 03-23-2013, 11:13 PM
coco135's Avatar
coco135 coco135 is offline
Mein Auto: 750i
when decoding my 2009 750 (F01) i see this installed
S2VBA-REIFENDRUCKANZEIGE-Tyre pressure display
HU_CIC-3001 EXBOX-RDC_SAFETYaktiv / Werte=01 *confirmed
IcmKod_B_SA2VB = verbaut *confirmed
I do not have CIC i do have HU_cic so i confirmed:
HU_CIC:
RPA_CIC = nicht_aktiv
RDC = aktiv
RDC_SAFETY = aktiv
On the bottom of the screen i see ' Status: TPM active'
I just get the green marking with no data, any ideas?
Old 03-24-2013, 08:09 AM
HU_CIC:
RDC = aktiv
RDC_SAFETY = aktiv
CIC is HU_CIC.
You clearly have the 2VB hardware, but RDC_SAFETY = aktiv is not working. Are you even getting the box displayed which shows dashes for PSI and DEG, or you are getting nothing new at all?
Did you force the Werte Value = 01, or just change the drop down from nicht_aktiv to aktiv?
Old 03-24-2013, 08:42 AM
coco135's Avatar
Mein Auto: 750i
CIC is HU_CIC.
Changing it from the drop down list changed also the Werte value
Attached is the screen shot
i used to see dashes never did i got actual reading but now i dont have the dashes also
Edit: after another reset I see the dashes
Name:	TPM SCREEN.jpg
Old 03-24-2013, 09:40 AM
Ok. So the coding works, but the readouts do not. There are many cars like yours, but small as a percentage of the whole, where it simply refuses to work, and without explanation. It seems though it is early Fxx cars like yours that are affected, so it may be the firmware on the RDC module.
Old 03-24-2013, 09:44 AM
coco135's Avatar
Mein Auto: 750i
Got it. Can I update the firmware myself Or is it too complicated?
Old 03-24-2013, 10:04 AM
You can flash the RDC module in E-Sys, but the process is undocumented, and at worst you can brick the ECU.
Old 03-24-2013, 06:31 PM
coco135's Avatar
Mein Auto: 750i
mmmmm...i think i'll survive without the data
Old 03-24-2013, 07:04 PM
intex98 intex98 is offline
One more datapoint - Aug '11 build F10 here and no temp or PSI readings on the TPMS screen; only dashes
Oh well.
2011 535i (8/11 production)
Space Gray, Black Dakota/Aluminum, Premium 1&2 Pkgs, Sports Pkg, SAT, Dynamic Handling Pkg, Convenience Pkg, BMW Apps
2007 335i Coupe (sold 9/11)
Titanium Silver/Black Leather/Aluminum Trim, Auto, Paddles, Premium, Sport, Navigation, RTTI, Comfort Access, PDC, Rear Sunshade
2003 X5 3.0i (sold 11/06)
Titanium Silver/Black Leather/Dark Wood Trim, Auto, Premium, Sport, Navigation, Rear Climate
Old 03-24-2013, 07:16 PM
Oh well.
I don't know. It works on my 10/10 build. Yet, maybe 5% of cars seem to have problems.
Old 05-03-2013, 07:09 AM
dmunz dmunz is offline
Mein Auto: 535i GT
A new twist...
Originally Posted by dmunz View Post
Ok in a WTF moment my TMPS is now showing data. I bumped a curb pulling out of the bank and switched to the display just to check and the pressure and temp data is now there.
No idea why I have not messed with coding in months and my car has not been in the shop.
We will see if it stays...
FWIW
DLM
PS I did scuff my rim dammit. Not too bad but I know it is there.
I chagned my tires (Michelin Pilot Sport A/S Plus) and the numbers are still there but they are all messed up. The front right is the most off (temp +10 degrees over the other three and the pressure is 4psi down). The other three are consistant with temp but the pressures are all over the map.
Is this something that takes time to stabilize? I've reset the system and the tires are all showing green. I assume it reads the pressure at reset and will monitor that correctly but I am a little worried that it wont.
Going to a non-runflat I want to make sure I have a good warning system even if I can't get accurate numbers.
TIA
DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g.
Old 05-03-2013, 08:42 AM
snj1013 snj1013 is offline
Mein Auto: 2011 528i
TIA
DLM
My temps and pressures are all pretty consistent. The pressures read within a couple of tenths of my handheld gauge. Cold tire temps initially are pretty close to ambient temps, so I am assuming they are close as well. Sounds like yours have some issues.
Old 05-05-2013, 09:09 AM
Mein Auto: 535i GT
All better now...
I guess it just took some time to stabilize. I dropped all the pressures below the recommended limits (32 front, 35 rear), pumped them back up, hit the reset button and put a couple of hundred miles on the car. Everything seems to be where it should now.
And the Michelins are great. I wasn't too impressed at first (no bad, just not the rave I expected from all the forum traffic on RFs) but after some miles I really can say dumping the RFs makes the car ride better.
FWIW
DLM
Old 01-21-2014, 06:55 AM
zev zev is offline
Mein Auto: F20 118i
Hi Shawn,
how to retrofit the RDC on F20/F30? have anyone discuss it before?
all the item list, right?
36106857938*1
36106856227*4
36146792829*4
and another question, I retrofit NBT on my F20 with HU_entry, and the touchpad idrive controller does not work. someone said I have to get new CAN from NBT, touchpad idrive controller use another CAN bus instead of the old wire. could you help on this?
thanks a lot!
Old 01-21-2014, 07:26 AM
Chuck W.'s Avatar
IMHO, this is not a hardware problem. It is a software issue. I had this feature then after a software update at the dealer it can not longer be activated.
Old 01-21-2014, 08:33 AM
And you have gone back and coded but RDC_SAFETY = aktiv and now the temp and PSI no longer show?
Old 01-21-2014, 08:43 AM
Chuck W.'s Avatar
I'll ask Chase, but he has tried several times without success. Thanks.
Old 01-21-2014, 09:46 AM
Tuesday Tuesday is offline
Mein Auto: .
Old 01-21-2014, 10:45 AM
iansanderson iansanderson is offline
Mein Auto: 2014 335i M-Sport
Model: 335i 6MT
Build Date: 08/13
Delivery Date: 09/13
Status: Not Working
Did you ever change the wheels and/or tires: no
TPMS Type: original, nothing replaced.
Tires: Air
Old 01-23-2014, 09:03 AM
GermanRoots GermanRoots is online now
Mein Auto: 2012 550i M-sport
I coded the TPMS last week and had no issues getting the info to display. I do question the accuracy of the information. For those of you who have successfully coded, do you feel the temp and pressure values are accurate? Do I need to reset TPMS to force a recalibration or something? Thanks!
Old 01-23-2014, 10:09 AM
I have checked my displayed pressures vs my hand held tire gauge and the pressures are within +/- 0.5 psi, so they appear spot on.
As far as the temperatures, I can only add that the displayed temperatures seem to be within a degree or 2 of the ambient temperature when I first start my car in the morning. So once again, my experience is that the temps seems to be fairly accurate as well.
Resetting the TPMS system doesn't calibrate the sensors. I believe it just relearns the thresholds for alarms.
Old 01-23-2014, 10:00 PM
zev zev is offline
Mein Auto: F20 118i
detele VO 258, add 2VB. Code hu_nbt/cic (63)
Old 01-24-2014, 03:05 AM
You can't just change coding from FTMS (RPA - Reifen Pannen Anzeige) to TPMS (RDC - Reifen Druck Control) and have it work. The hardware is different, and FTMS has no actual sensor to measure Pressure and Temp as it determines low pressure condition based on tire rotational speed.
