E30 (1982 - 1993)
'86 325es dashboard and seatbelts
Greetings all,
I'm looking for info to replace the dashboard and seatbelts on my '86 325es. Any idea where I can find removal/installation info? Thanks in advance. HB |
Google is your friend
I did a search and this is the first thing that popped up. http://home.comcast.net/~cdeegan9/da...shboard_1.html
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap http://www.bimmerfest.com/forums/sho...36#post7573736 M20B27 for sale in Cincinnati |
I found that one, too. Thanks. Any info on the seatbelts?
Its just bolts and trim. Take pictures of any trim you remove. Very straightforward job. Just remember the trim will be old and brittle. While you have it in bits maybe remove the sets for a good cleaning and then do the carpets?
I have a word document with pictures I could mai to you
