E30 (1982 - 1993)
Old 10-06-2012, 07:41 PM
BMWFatherFigure's Avatar
Old School
I suggest taking stock injectors to FI shop who can do an off car clean, flow and spray pattern test. Has worked very well for me in the past. I have heard horror stories about tank aditives that 'clean' injectors.
Current:
E38 Parts Car
Previous:
Old 10-10-2012, 03:51 PM
Alfa Seltzer Alfa Seltzer is offline
Mein Auto: 1986 Alfa Romeo Spider
I ordered a new injector but after 5 days it still hasn't arrived.
I pulled the injectors, soaked/flushed them with kerosene and installed new seals. It looks like the kerosene has revived the dead injector.
Still idles a little funky but this sounds like its hitting on 6 to me. Adjusted the valves to .010 cold but may need to go in and tighten them up a thou.
**EDIT**
Shortly after taking that I realized the bolts for the bracket connecting the intake/VC actually seal vacuum. Popped those back in and shes idling pretty well.
Old 10-10-2012, 05:26 PM
Old School
The injector clean would have saved the cost of a new set. Idle is poor most likely due to bad spray from injectors or low fuel pump pressure. Check them both and correct any faults. Then go for a long (local) drive to get things moving again. Gentle on brakes etc and keep speeds down. I suggest local only as you have to restore reliability - long walks should be reserved for sunset beaches!
Current:
E38 Parts Car
Previous:
