Old 02-01-2013, 01:45 PM
Swiezymj Swiezymj is offline
Mein Auto: 745Li
Cool No Heat suddenly after flushing cooling system
I have a 745Li and I just replaced my radiator hose both upper and lower as well as the overflow box and now I cant get any heat in the car is thei related. The overflow is at the corret level and I'm no longere seeing a lowe coolant level alarm. Help I'm freezing!!
Old 02-02-2013, 08:19 AM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
With the car cool, remove cap from reserve tank turn on heat to full leave fan on low. For about 5min or so.... Then turn on car and watch for air bubbles comes out from the small pin hole in the tank , return cooling line. If that's not working for you, it might be your Aux pump that feeds your heat cord.
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
Old 02-02-2013, 08:30 AM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
Originally Posted by rideme2 View Post
with the car cool, remove cap from reserve tank turn on heat to full leave fan on low. For about 5min or so.... Then turn on car and watch for air bubbles comes out from the small pin hole in the tank , return cooling line. If that's not working for you, it might be your aux pump that feeds your heat cord.
+1
Old 02-02-2013, 08:54 AM
nonstop nonstop is offline
Mein Auto: m roadster/745LI
Heat
If you had head prior to changing out the hoses then I would think your system is air bound.
Follow what the other post said. I swapped out the T-stat on mine and it took awhile to get all the air out. Had the same issue on our M Roadster. Threw a belt and slight overheat. Lost coolant. Replace all the pulleys and belt. On her car I let it sit overnight with the Rad cap off and topped it off in the am. No issues as of yet..
Opps. HEAT, I meant heat!!!!! to funny
heater problem
