E34 (1989 - 1995)
Old 06-06-2012, 10:12 PM
kaytbugsdad kaytbugsdad is offline
Mein Auto: 1995 BMW 525i
525i wont start......
I'm new to the world of BMW's (newer ones,anyway)....... I have a 1995 525i with the EWS system in it........ Someone worked on it before me, and replaced the ignition lock cylinder housing. Now the car won't start, and I noticed that the antenna ring that goes around the lock cylinder has been kinda rigged together (copper wires for the ring are just twisted together to the green wires of the connector, then plugged into the little black box mounted to the steering column)........ I was wondering if replacing just the antenna portion might cure the problem, or should i just take it to a shop and let them fix it???? I'm pretty good with electrical (I own a Ford Ranger with a Thunderbird Turbo Coupe motor swap done by me), this is kinda something new to me...... BTW, the key is the one that came with the car originally, as well as the lock cylinder. Any help would be GREATLY appreciated!!!!!
Old 06-07-2012, 07:11 AM
supertech777's Avatar
supertech777 supertech777 is online now
Mein Auto: 1995 525i
I had the same problem and bought a stage 1 chip with EWS delete in it , went the route of buying a new antenna ring , to my surprise didn't work to . I bought the EWS delete chip from eBay for around 50 to 60 dollars and it works great , and is working just fine . It also added an extra 18 horse power removes the speed governor and brought my redline up 2k rpm . Search this site for ews delete . Steve bmr_lvr has a great write up on it ... But all I had to do was replace my chip on the dme . Welcome to the fest my name is Noel
Sent from my Desire HD using Bimmer App
Old 06-18-2012, 11:58 PM
Got the chip off Ebay, and unplugged the EWS module, spliced the #1 and #3 wires together, clipped the big green one........ Fired up and runs beautifully now!!!!! Thanks for all the help!!!
Old 06-19-2012, 05:49 AM
That's awesome
Old 06-19-2012, 06:47 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
That's great
I'm a little confused though. I was thinking that the chip alone would bypass the EWS so you would not need to do any of the wiring modification. Did you by any chance try to crank the car after only replacing the chip? I would love to know if it would have cranked without having to do the wiring modifications.
The only thing you did differently than the EWS write up I did was to add a chip rather than swap to a red label DME.
If you don't mind me asking, how much did the chip cost on Ebay? Used red label DME's go for around $50-$75 in my area. It seems that these cars are reaching an age where the DME or the EWS systems are starting to fail somewhat regularly.
Anyway, glad you got it running again.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-19-2012, 10:27 AM
Originally Posted by BMR_LVR View Post
That's great
Hey there Steve it's Noel , remember you helped me with the same problem this past November . Well anyway I did all that splicing and green wire cutting and it still didnt start , the only thing it did was turn the stater , so when i went the ews chip delete route the engine fired right up . I guess there is more to the mapping of the original chip with ews2 . So to make a long story short just splicing the 1 & 3 wires and cutting the green wire on the diagnostic plug on the engine bay is not enough , it still needs that ews2 delete chip ! tried calling you earlier .
Noel
Old 06-19-2012, 10:57 AM
BMR_LVR's Avatar
Humble E34 lover
Noel
Hey Noel. I left you a voice mail as well. I was away when you called.
In regards to the above, I completely understand that just doing the wiring modification will not by pass the EWS and allow the car to start. My question was, in the OP's situation, would his car start with ONLY the chip change. He noted that he did the wiring modification as well as putting the chip in. I was of the understanding that the chip by itself should bypass the EWS and no wiring modifications would be needed.
Any thoughts on that?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-19-2012, 11:22 AM
In my case, just the chip alone would not allow the car to start, I'm guessing that the starting circuit in the EWS module was bad, so I removed the module completely, and did the wiring modification afterwards...... Hope this helps!!!!
Old 06-19-2012, 11:37 AM
BMR_LVR's Avatar
Humble E34 lover
Thanks.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
