BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#51
In any event, besides the fact that we go though this every single time a new ISTA/P comes out, and E-Sys v.3.18.4 has yet to not work with the new PSDZdata files, in this specific instance, we have already seen where both users DESI4life10 and RASHID007, using E-Sys 3.18.4 could not code the FEM_Body ECU on brand new F30's using the v.46.3 CAFD_00000794-002_020_026 file; however, when it was updated with the v.46.6 CAFD_00000794-002_020_029 file, they were able to successfully code FEM_Body ECU with E-Sys 3.18.4.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#52
I still think it will work regardless of E-sys version. How does one obtain these newest versions of the ISTA data is where we need to channel our collective energy. WIth the community as large as it has grown, a group effort to get enough funds to get these updates should not be a problem. We need to find the source of where to get it from. Anyone have any ideas how and whom do we contact as a direct source to get this data??? |
#54
Hello gu
I need your help. look i have the 48.0 data file but when im running the e-sys its giving me error which was coming with our firned Big Sarge ! Any one can help? im using I com and with 3.20 V Thanks |
#55
READ FA ERROR:
Few have reported "READ FA Error........" This kind of error you will get when after clicking the Connect button and picking up the right SELECTOR, you do not select "CONNECT via VIN". You might get a messge that EYS connection established (..162) but infact it is NOT. |
#56
#57
I'm having some trouble connecting to my car all of a sudden.
I can run the ZGW search and it will find the car but esys gives me a grayed out box for connecting via vin and a message that says "No ZGW Available" I have tried ripping out Esys and reinstalling to no avail. Firewall is off for this connection. and I am able to see the list of Targets just no connect bus. I was also able to do some coding before on this laptop with no issues, this problem just cropped up. Any ideas?
2013 - Monte Carlo Blue M5 2011 - X5 35d ------Retired---------------------- 2007 - Jet Black 335i 2003 - Silver Gray Metallic M3 2006 - Black Sapphire M6 |
#58
#59
Not that I am aware of on the laptop. The laptop is exactly the same it only gets used for coding.
The car was in for service and had an update run but I had been able to get in to it since then but only once. Edit: got it working on another computer... odd but at least I can code again.
2013 - Monte Carlo Blue M5 2011 - X5 35d ------Retired---------------------- 2007 - Jet Black 335i 2003 - Silver Gray Metallic M3 2006 - Black Sapphire M6 Last edited by DaKoren; 01-11-2013 at 01:37 PM. |
#60
connection problems
I was using E-Sys a while ago and had everything working fine. Fast forward a year, I took my 2012 328i to the dealer to take care of a recalled sensor and they reset everything I programmed. Well, I now have a new laptop so I had to download and re-install all the coding software.
The issue I'm having is that I cannot connect to the E-Sys software. In E-Sys the Connect via VIN box is grayed out and says No ZGW Available even though the ZGW software is clearly reading my VIN. One of the first tips in this thread was to make sure the "dist" folder is located within each of the mainseries folders, which it is. I also made sure the EDIABAS.ini file has ENET listed next to interface as another thread suggested. Attached is a screenshot of the grayed out VIN connection. Any thoughts? Am I not making a proper connection to my car somehow and if not how was the software even able to pull up my VIN if it isn't? UPDATE: Turns our one of my network cable wires broke at the solder joint. I can connect just fine now. Now I just need to find an updated HU_CIC data set or something because I cannot edit the file at all. O_o HU_CIC [63] [F343228] readCPS o.k. cafd_000000f9-007_006_009 Fehler: File for "cafd_000000f9-007_006_009" not found! [C012] Last edited by jeremy480; 04-24-2013 at 08:25 PM. |
#61
PM sent.
#62
I guess someone wanted to get a piece of all this hacking action and pad their pocketbooks a bit with some extra $$! ![]() Thanks for all your help, Shawn. You seem to be the resident expert around here. |
#63
#64
now i have the psdzdata 2.49.1, is possible to have a link to 2.49.2 thank Donato |
#65
PM sent.
#66
Hi my friend.
Hi Shawn,
I need the 49.2 Can you please PM me the links for 49.2 Thanks advance.
#67
PM sent.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
