Old 06-07-2012, 04:45 PM
bean 22 bean 22 is offline
Mein Auto: 745 Li
Question thrust rods? HELP PLEASE
Dealer told me that my thrust rods are cracked in half and must be replaced. I tried to look up the part and cant find it anywhere. I know that they are bushings but are they called anything else and does anybody no how much they cost? help im new to the BMW family.
Old 06-10-2012, 11:34 AM
JimmyW's Avatar
JimmyW JimmyW is offline
Mein Auto: 2007 BMW X5;2002 BMW 745i
http://realoem.com/bmw/showparts.do?...24&hg=31&fg=05
Depending on whether they are talking about upper or lower control arms they could also be called wishbone or tension strut.
Old 06-11-2012, 06:29 AM
roadfrog's Avatar
roadfrog roadfrog is offline
Mein Auto: 2003 745i
Thrust bushings. Tension struts. Extremely common problem on ALL BMW's. My wife's X5 needs them too with only 60k miles.
Old 06-11-2012, 07:48 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
+1.
If it's just the bushings and the ball joint at the other end is fine, you can buy a pair of the bushings at the dealer for around $90 and have your shop press them in.
Sent from my ADR6425LVW using Bimmer App
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 06-12-2012, 06:51 AM
roadfrog's Avatar
On Ebay you can get the whole strut for only a few more bills than trying to deal with the bushings alone (pressing out and in etc). Less of a hassle. I found some for the X% for only 135 dollars for the pair.
