E36 (1991 - 1999)
Old 06-29-2012, 03:51 PM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Get all the old stuff OUT.
LINKY Linky
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 06-30-2012, 01:16 AM
Dakota_leWarne Dakota_leWarne is offline
Mein Auto: 1994 318is
Thank you home slice
"if you look close enough... youll see my bumper is being held together with zip ties
Old 07-02-2012, 01:53 PM
the first bmw coupe trunk lid to come up for sale in a month is now on the back of my car.
Old 07-03-2012, 01:22 PM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
hey dakota, really impressed with your work. which DIY did you end up using for the PS fluid? Dougs domain looked good to me.
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 07-03-2012, 01:48 PM
Thanks, means alot that guys whith such nice cars like you think im doing a good job.
I used the Dougs domain one, i intended to do the optimal flush method but i guess i misplaced my only 22mm wrench and was working later on a Sunday and couldn't go get one. I ended up doing the simple flush but instead of using a syringe i unbolted the reservoir and turned it upside down allowing me to get about a quart of fluid out. I plan to do it again in theory getting all but 1/2 a quart out. as there was no improvement in the steering i feel i may have proplems further then old fluid though.
Old 07-03-2012, 02:01 PM
veteran011's Avatar
Mein Auto: 97 328is
Mine's being retarded. see my post here. I'll let you know how it goes.
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 07-05-2012, 02:23 PM
my baby... is legal
Old 07-05-2012, 02:45 PM
veteran011's Avatar
Mein Auto: 97 328is
what kinda problems are you having? i fixed mine with a dousing of PB blaster on the bearing. cant hurt to try.
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 07-05-2012, 06:10 PM
well.. i wish you didnt ask.. i opened the hood to spray down the the pivot points and found that someone left a wrench on a transmission bolt and it was rubbing on said pivot point causing the hard steering.
we can all pretend we dont know who left it there
Old 07-05-2012, 06:28 PM
veteran011's Avatar
Mein Auto: 97 328is
Well at least its a cheap and easy fix!
Sent from my DROID4 using Bimmer App
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 07-05-2012, 07:29 PM
very true, i have a problem with leaving tools in there, i left an alen wrench on the control arm which pressed up against the ac unit which was causing irregular idle.
Old 07-05-2012, 07:32 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
PB Blaster WON'T fix this!
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 07-06-2012, 10:34 AM
Mein Auto: BMW
Done..
my baby... is legal
And Done..
+ 7000 for this guy ^
fcuking cojones
Old 07-06-2012, 10:40 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yeah, Dakota gets mad props for sticking with it.
1998 BMW 328is
1966 Pontiac GTO
Old 07-06-2012, 10:50 AM
Mein Auto: BMW
Originally Posted by zegerman View Post
yeah, dakota gets mad props for sticking with it.
+10
Old 07-06-2012, 10:53 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Good job.
Make sure you collect all your tools before you close everything up.
Like a surgeon leaving a scalpel in somebody, it could be bad news.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 07-06-2012, 01:06 PM
Ive been driving her a bunch today and yesterday, the exhaust manifold is still leaking a bit, i was unable to tighten all the bolts, but the big kick in the pants is its throwing the mass air flow sensor code agian.
Old 07-06-2012, 02:09 PM
i got a 1214 which is apparently not a code, im assuming its a
1215 bad maf
1213 lambda control 2
then after unhooking the battery and driving around the block it got
1222 lambda control 1
does the same exact thing as it did before i changed out my maf
Update, i checked the codes again today after driving a bunch today and yesterday and the maf code has not come back up after clearing the codes, im thinking it may have just been stored from before the newer maf. Any one know where to look first to fix my lambda control 1 code?
Old 07-10-2012, 11:51 AM
Old 07-10-2012, 12:36 PM
Mein Auto: BMW
Lambda Control 1 1222
This code is stored when the DME detects excessive deviations in the air-fuel mixture (too rich or too lean) for longer than 10 seconds.
Possible causes:
Fuel tank ran empty, Incorrect Fuel Pressure, Injector valve defective or coked,
Engine Temperature Sensor defective, Secondary air leak, Fuel evaporation control system defective,
Air Flow Meter defective and/or the combustion is being disturbed by mechanical failure
(Spark plugs,, compression, intake/exhaust valves, ...etc.)
I would look at the 02 sensor first..
disconnect the o2 sensor at the plug when the car is cold.
start the car and warm it up.
if the problem doesnt return, o2 sensor bad.
o2 sensor is bypassed until operating temperature is reached.
Then double check for vacuum leaks for the umpteenth time..
Does CEL go away when you blip the throttle?
No fuel leaks?
Is your evap system for the fuel tank breathing properly?
Are all the gaskets on the intake manifold seated proper?
Not Sure? Pull/push gently on intake manifold.. look/listen for idle RPM changes..
Idle Control Valve?
Throttle Position Sensor?
stab in the dark: engine temp sensor..
Old 07-10-2012, 02:14 PM
THANK YOU!!
Ill try the o2 sensor first.
I just checked all my vacuum hoses again yesterday and insured that none are leaking or are pinched.
yes if i rev it past 1-1.5k it truns right off, it comes on when i stay at any rmp for 10-15 seconds but goes away if the rpms drop or rise.
No fuel leaks that i can tell and ive spent quite a bit of time under the car so i assuem i would have noticed.
Idle control valve has been cleaned and if it is unpluged the car will die.
^^ for all that stuff i have absoluty no clue
Old 07-10-2012, 02:30 PM
Mein Auto: BMW
THANK YOU!!
Find out.
Inspect, check, clean, the throttle position sensor on the side of the throttle body.
Inspect, check, and find out if your intake manifold is leaking.
Check engine temp sensor also.. If it works.. you'll know.
There is a tiny hose on the fuel pressure regulator that tends to crack over time.
It attaches to the under side of the intake manifold and its very possible a leak in that tube would not be detected.
Vacuum check..
-intake boot to valve cover
-intake boot to ICV
-ICV to manifold
-manifold to FPR
-manifold to brake booster
-TB to charcoal canister
Old 07-10-2012, 02:44 PM
Vacuum check..
-intake boot to valve cover (done)
-intake boot to ICV (done)
-ICV to manifold
-manifold to FPR (done)
-manifold to brake booster (done)
-TB to charcoal canister (done)
It attaches to the under side of the intake manifold and its very possible a leak in that tube would not be detected. ( if this is the one the runs from under the throttle body to down by the drive side wheel well, its been replaced and it was a pain in the ass to do so)
(the throttle position sensor has been cleaned as has the inside of the throttle body and passages.)
once my engine is cool, i will yank the crap outa that thing
Old 07-10-2012, 03:13 PM
i unplugged the oxygen sensor, let it warm up, and then took it on a drive to alburtsons, not a long drive but a few miles and enough that the light would have normally come on. it did not come on at all.
does this mean the o2 sensor is bad? the only difference in the drive was the idle did not always drop down as low.
Old 07-10-2012, 04:39 PM
Mein Auto: BMW
I would say 02 sensor is suspect.
Check it, swap it, see if issue returns.
