Old 06-10-2012, 01:25 AM
Howard.bias Howard.bias is offline
Mein Auto: 645ci
Disc changer in 645ci
I have a 2004 645ci, I guess I have a disc changer in it but I can't seem to find it. It's not in my glove box, where is it located? Or, do I even have a disc changer in my Beemer?
Old 06-10-2012, 11:13 AM
Yorgi's Avatar
Yorgi Yorgi is offline
It should be in the glovebox. There is a very slight chance someone installed an aftermarket one in the trunk behind the carpet.
Just go into iDrive > Entertainment and see if CD1 to CD6 is available. You will see AM FM CD (the CD in the dash) then you should see 6 more CDs available, if not then you don't have a changer installed.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 06-10-2012, 03:07 PM
Mein Auto: 645ci
In idrive it does say cd1-6. I click on it and nothing happens. I tried to insert anther cd in the cd player but of course if doesn't take it cuz there is already one in there. I checked the glovebox....... Nothing, I checked the trunk and........nothing. I don't know if the cd changer comes stock on the 645 or do I actually have to go and install one. I don't see one anywhere
Old 06-10-2012, 06:16 PM
Yorgi's Avatar
If you see the CD1-CD6 then maybe the previous owner removed the changer. I would just grab a new one off eBay. It would interesting to hear from some of the owners on here that removed their changer to install an iPod kit to see of the CD1 to CD6 disappeared from iDrive.
Here is the retrofit part number.
And the CD Changer part numbers.
I would look and see if the cable for the changer is still installed in the golvebox.
'04 M3 - track
Old 06-10-2012, 09:47 PM
Mein Auto: 645ci
There is a cable that just hangs there in the glove box, I thought it was a cell phone charger. I guess it is the cable for the changer. The cd1-6 is in my idrive but it's not highlighted its dimmer that the rest of the stuff. I'll look into buying another one if it's not too expensive thanks for all our help
Old 06-11-2012, 11:18 AM
amennrahh's Avatar
amennrahh amennrahh is offline
BM6er
Mein Auto: 2005 BMW 645ci
There is a slight possibility that the cable that you are referring to is indeed a cable for an ipod. You should post a picture of it so that we may identify the cable.
SEMPER FIDELIS
Old 06-11-2012, 05:55 PM
Yorgi's Avatar
That is a very good idea. If the changer is missing it is very likely the owner removed it to install the iPod cable (you can't have both iPod and CD changer with an OEM setup). To have both you need something like the Gateway 500.
'04 M3 - track
Old 06-11-2012, 06:01 PM
Mein Auto: 645ci
Ok so the cable we are talking about apparently is an iPod cable cuz I hooked my iPod to it and it connected. Now i'm having an issue switching my radio in idrive to iPod mode. I couldn't figure it out. You guys know anything about that?? Btw thanks for all you're help
Sent from my SGH-T959V using Bimmer App
Old 06-13-2012, 06:57 AM
amennrahh's Avatar
BM6er
If this iPod interface is the Dension 500 unit you can retrieve detailed operation instructions on their website.
SEMPER FIDELIS
Old 06-13-2012, 08:11 AM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2012 650 Coupe
And if it's the BMW MOST adapter, you just go to CD 1-6.
Nick / TopDownInFL (sans the "top down")
2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound
Previous Bimmers:
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 06-13-2012, 06:36 PM
TxTaz's Avatar
TxTaz TxTaz is offline
Mein Auto: 2010 650i Coupe
My vote is an iPod cable.
I would trace it back to see what you have.
Also I have had a cable go bad before so don't rule that out.
Taz...
2010 E63 Black sapphire metallic
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
Old 06-14-2012, 04:28 AM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
I have the Dension Gateway 500 & the CD1-6 is there. I think there are two ways to fit the Dension, like an iPod retrofit or a CD Changer retrofit (or replacement if the car already had a CD Changer installed).
