Help-Nav screen has gone dark! - Bimmerfest - BMW Forums
Old 06-10-2012, 11:54 AM
lcadena lcadena is offline
Mein Auto: 528i xDrive
Angry Help-Nav screen has gone dark!
Yesterday I turned on my seven-month-old 528xi F10 after leaving the movie theater and, lo and behold, the nav/infotainment screen did not come on at all. The radio and iPod play just fine, and I can switch between then with the steering wheel scroll wheel and buttons, but the main console screen is completely black. I also used the iDrive controller to switch station presets (I had turned off the car while the screen was on the radio presets) without incident. Does anyone know what could cause this, and if this is a common problem?
I've got an appointment to take the car in for service on Friday (it's under warranty, after all), but I'm curious to see if others have experienced this, too.
Old 06-11-2012, 04:45 AM
Jack the cat Jack the cat is offline
Jack the cat
Mein Auto: 2011 535i
I have had two issues with my screen:
1. Back light was not on. I could see the words, but were very dim due to no backlight. Turned engine off, then on, and all worked fine.
2. Right side of split screen was black. Left side so ok. Car had set in sun and heat several hours. Changed to full screen then back to split screen and all was fine.
Didn't think to mention these during routine maintenance visits.
2016 X3 35XI - Mineral White Metallic / Mocha Nevada Leather / XLine / Driver Asst+ / Premium / Technology
Prior:
2011 535i - Imperial Blue Metallic / Venetian Beige Dakota Leather / Light Wood Trim - Premium 1&2 - Smartphone integration
Old 06-11-2012, 05:36 AM
miotoo miotoo is offline
Mein Auto: F10 520d
Did you try to hold the volume/mute button in for 30 seconds to reboot the cic?
F10 520d Deep Sea Blue 11.04.2011/16:24
Retrofitted:
5DF Active Cruise Control with Stop & Go incl. Collision Warning with Brake Function /ver. 1
2TB DEC Switch for Normal / Sport / Sport+ Writeup: http://www.bimmerfest.com/forums/sho...d.php?t=685869
8TH SLI Speed Limit Info / KAFAS 1
5AD LDW Lane Departure Warning / KAFAS 1
319 Universal Garage Door Opener
6WA Instrument Cluster with Extended Contents
Old 06-11-2012, 06:52 AM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Mein Auto: 2007 MDX
good to know about that trick!
2011 535i
Sophisto Grau / Oyster - Black Nappa, Anthracite Wood Gone but not forgotten.
Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss.
Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians
Old 06-11-2012, 07:06 AM
mkossler's Avatar
mkossler mkossler is offline
Matty K.
Mein Auto: 2014 750Li Black Sapphire
Also, if you have an older iPod plugged in via glovebox USB, you might want to try unplugging it. Had this issue some time back with a 40 Gig click-wheel vintage unit.
2014 750Li Black Sapphire, Veneto Nappa, Lighting pckg, Executive pckg, Driver Assist Plus pckg, M Sport
Past: 2011 535i (8/2011 build) Jet Black, Black Dakota leather, Dark Wood, Convenience, Premium 1 & 2, SmartPhone, BMW Apps
2011 528i Alpine White
2005 X5 3.0i Jet Black
1995 540i Oxford Green
1972 2002 Ti, Alpine White
1982 320i 1.8l Graphit
1977 320i 2.0l Korall
Old 06-12-2012, 04:43 AM
Thanks for the tips and replies, everyone. Yesterday evening after work the screen came back on all by itself when I turned the car on to drive home from work. Not sure what the cause was, but I'll keep the solutions in mind if it happens again!
