Dipstick O-Ring question - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-07-2011, 07:54 AM
heyjerky heyjerky is offline
Mein Auto: 01 325i
Doing my CCV swap I decided to replace the dipstick O-ring. Should it put the O-ring onto the tube of the dipstick and then insert into the engine, or should I put the O-ring into the hole in the engine and then insert the dipstick?
When I put it back together I just slid the O-ring onto the dipstick tube and put it all back together, however looking with a flashlight I can see the O-ring sitting right on top of the hole, when I removed the original it was down in the hole, so I'm doubting it will seal right.
Thoughts?
Old 01-07-2011, 08:21 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '17 340iGT
Been there done that. It is a little tricky. The O-ring needs to be pushed into the bore. If it's sitting on top, you will leak oil. What I did was to first clean the bore/hole very well and made it as smooth as possible. Put the O-ring on the dipstick tube first up to the lip. Then, even though this is all surrounded by oil, lube it real well. I used an actual rubber lubricant but you can use something like petrolium jelly. Then just push down hard on the dipstick tube, wiggling and twisting while pushing. I used the hose bracket on the tube for more leverage. You should be able to walk the o-ring down into the bore where it belongs. Remember the O-ring is sealig via the inner and outer edges, not the top and bottom.
Old 10-19-2014, 01:39 PM
> Complete list of all o-rings (by size & by part number) to buy when ordering parts
For your basic oil change, here's a picture of the related o-rings that you can replace...
See also:
- How not to replace the dipstick guide tube lower large 0-ring (1)
