Old 06-12-2012, 10:22 AM
dehard dehard is offline
Mein Auto: 2001 BMW Z3
Bmw z3 roadster convertible top clear plastic rear window
I just purchased this replacement rear window for my 2001 Z3 on eBay and it installed easily and now the top looks like new now. Only $149.95 Highly recommended. The window zips out and a new one is just zipped in. Go to ebay and type in this itm number in the search: 150822892830
Old 06-22-2012, 08:46 AM
centralVAZ3 centralVAZ3 is offline
Mein Auto: 2001 BMW Z3 3.0
I just order a window from this seller as well
The seller has a new item #. Not certain why. The new # is 150839598053.
Anyone else use this replacement window and any insights/war stories about the install?
Old 06-22-2012, 10:38 AM
flossy21 flossy21 is offline
Mein Auto: Ford Explorer
Here you go
Here you go...
http://forums.bimmerforums.com/forum....php?t=1681426
Also - I bought the ebay window as well. I have not installed it yet. I am told it is the exact same seller as the emiata window which you can get for $90 shipped.
http://emiata.com/Z3Window.asp
YMMV
Old 06-24-2012, 06:52 PM
Thanks flossy21!
Old 07-24-2012, 04:27 PM
Z3Lee Z3Lee is offline
Mein Auto: 2002 Z3 Roadster
Emiata Window Replacement
I recently bought an Emiata replacement window for my 2002 Z3 and but for a botched install job by yours truly I think it would have been a great alternative.
The installation was rather easy and can be done by just one person.
Here's the story.
My initial attempt to install the window had me falling prey to the oldest mistake in the book - zipping it in in the wrong direction. My second attempt had the window in about 15 minutes later and but for a small ripple in the window all was good.
Let this be a lesson - don't let perfection be the enemy of good enough. I should have left well enough alone. Instead I unzipped and tried a third time during which I ripped the zipper away from the top in one of the lower corners and that was the ball game. Many additional attempts and a couple hours later and I just couldn't get the teeth to mesh at the point where the zipper had torn from the top. So much for a $100 solution, next up, the $800 solution - a new top.
Note: The Emiata window DOES NOT come with the plastic piping around the edge. Apparently that is a patent held by BMW. As such, you will end up gluing the canvas edge of your top to the nylon edge of the window.
Two things:
1. Yes the job can be done by just one person. Instead of having someone hold the window in place just lay the window on the trunk (use a blanket to protect your trunk and new window of course) then hang the edge of the new window over the back edge the trunk and line it with your starting point on your top. This way you can easily stand to one side of the car or the other and reach across to work on getting the zipper started. This is much easier than attacking it from inside the car.
2. Remove your antenna so you don't bump into it and snap it off while working.
Hope this helps somebody.
Lee
Old 07-25-2012, 07:30 AM
ALM168 ALM168 is offline
Mein Auto: Z3, e46, Ford Explorer
Question: If you glue the edges down using the Emiata window, will the glue release the edges the next time you need to replace the window? Has anyone done this?
Al
Old 07-25-2012, 09:17 AM
Al,
That would be my guess. The glue is a rubber cement type so it's not a "permanent" hardening type of glue. It's the same glue the factory uses to install the original window. The window that comes with the car also uses this type of glue in addition to the piping. If you want a twice installed Emiata window but never used for cheap let me know. I have one.
Lee
Old 07-25-2012, 09:39 AM
Lee,
Thanks for the reply. I believe that I can get one more season out of my original window, but will keep your offer in mind.
Al
Old 07-25-2012, 12:20 PM
dkindig dkindig is offline
Mein Auto: '01 Z3 3.0i Roadster
Originally Posted by Z3Lee View Post
Al,
Lee
Actually, the factory window comes with a thin border of tape around the outside of the window next to the piping. The paper covering is peeled off after installation and then the top material is inserted under the piping.
The canvas will come up okay if you ever need to lift it for some reason. As a matter of fact it will come up on its own after a while and you will find your self constantly reapplying glue to keep it looking "decent". The previous owner installed an eMiata window for the sale and I got tired of the canvas trim constantly coming up and looking like crap so I went back with an OEM window. I had to scrub all of the glue from the canvas strip off the top material for it to look decent again.
For the OEM window, the best adhesive to use under to flap when tucking it in is Permatex Clear Flowable Windshield Sealant. It may work well for the canvas edging on the eMiata window too, but you'll have to be more careful with the application.
Old 07-26-2012, 08:42 AM
wmcq6 wmcq6 is offline
Mein Auto: 97 Z3 1.9L
Al,
Lee
$$for shipped to 06260?
Tired of not driving due to zipper and window having stitching needing to be replaced so figured I might as well look at replacing window too.
Old 07-28-2012, 02:58 PM
I would like $50 plus shipping, what ever that might be. Couldn't be more than $10 UPS ground.
Lee
Old 08-08-2012, 03:54 PM
Dan Brush Dan Brush is offline
DansZ
Mein Auto: 2001 Z3 Roadster
Three questions please: Is the trim on this window attached or does it need to be glued on after? With the time since you have installed it has the trim stayed attached? Do you drop your top often? Thanks, Dan
Old 08-08-2012, 03:59 PM
DansZ
How is your newly installed Z3 rear window standing up? Do you drop the top often? Does the "high quality trim" stay in place as advertised?
Would you purchase this product again? I need to make a decision soon, but unsure of the Emiata trim and fastening? Thanks, Dan
Old 08-08-2012, 04:06 PM
Dan,
I ended up putting a whole new top on because as I was trying to install my window my top ripped. BUT, I did have my replacement window in and from all indications it was a good fit. I cannot attest to the longevity of the replacement window but for me the Emiata window seems like a good solution.
I can sell you my brand new Emiata window for $50 plus shipping. I had it installed for about 5 minutes then noticed that I had put it in crooked so I took it out and tried again - that's when I ripped my top.
Let me know if you're interested.
Lee
Old 06-20-2014, 11:23 AM
goodhikers goodhikers is offline
Mein Auto: BMW Z-3 2.8l
Cool Alternative adhesive/tape for securing canvas edging
I have tried the Permatex sealant on a previous Z3 replacement window...it works, but I had to apply it several times and--as a semi-liquid--you have to be very careful that it doesn't get on the visible part of the canvas.
But I may have found an alternative: special 3M Scotch adhesive "tape": Scotch ATG Adhesive Transfer Tape 924 Clear, 0.50 in x 36 yd 2.0 mil (Amazon $10) or Scotch ATG Adhesive Transfer Tape 924 Clear, 0.25 in x 36 yd 2.0 mil (Amazon $6). The only difference between the two is width (one is 1/2 inch, the other 1/4). I used the 1/2 but the 1/4 might work just as well.
This transfer "tape" is not really tape. It is a VERY sticky adhesive surface-to-surface but elastic when pulled from the end like a rubber band. If any of you have used the 3M wall hooks, those work in similar fashion; the adhesive strip holds the hook securely on the wall, but when you want to take it off, you pull the adhesive strip straight down and it comes off the wall without leaving any adhesive.
This tape works the same way. I successfully used it to secure the canvas edging on my 1998 Z3 and its second replacement window.
How I used it: Because this adhesive is so sticky, I had to cut it into small sections to fit them around the straight and curved parts of the piping. Six inches was about the maximum I could use. I then pressed the adhesive strip onto the small lip which extends from the piping and--because I used the half inch tape--onto just a bit more of the area above the lip. The stuff is SO STICKY, that as soon as you press down on the paper backing, it sticks fasts onto the lip and the paper backing almost slides off, leaving just a very sticky adhesive layer. After that, I pressed the canvas lining into place, using a very small flat screwdriver to drive the edging into the piping channel. This adhesive held the canvas edging better than the original "sticky" tape that came with the replacement window and did not leave any residue.
Since then (several weeks), in hot weather (>90 deg F), I've had the top up and down constantly, usually two or three times a day (when parking, etc.). The edging is still very secure...and hopefully will remain that way. Note: I will follow up in a few months with another report.
Some caveats:
1. This adhesive is meant to be applied with a special applicator tool (Scotch ATG 700 Adhesive Applicator - Amazon $42) which I found too expensive. In reality, I probably should have purchased it since the adhesive tape is pretty hard to manually install. Just a slight touch on anything (fingers, window, screwdriver, etc.) and it will stick and come off the paper backing. That's why I carefully cut it into small strips and applied one at a time. Tweezers helped.
2. Luckily, even though it's a very sticky surface-surface, pulling on it like taffy (note: it is stickier than taffy!) will pull the entire piece of adhesive off whatever it is stuck on, save plastic bags. This is important, as I did not align the tape perfectly and some stuck to the visible portion of the piping. Carefully using a very small pocket knife, I separated that portion from the hidden adhesive. Then I just pulled the small visible piece off without leaving any residue.
3. I purchased but did not use the 1/4 inch tape. In fact, that might work just as well, since it almost fits perfectly on the piping lip. But since I live in a hot climate AND I am about to ship my car once again overseas, I used the wider version for more adhesion. That definitely made it harder to install.
Bottom line: the Permatex solution works, but this adhesive tape seems to work as well without the danger of getting a liquid solution on the canvas or the window.
Hope this helps.
Ed G
Old 06-23-2014, 11:18 AM
someguy1313 someguy1313 is offline
Mein Auto: M-Roadster
nice tips on this... thanks
rear window, roadster window, z3 window
