X5 E53 (1999 - 2006)
The X5 SAV Forum |
Trans. Failsafe Prog.
Hi all,
I have an 05 BMW X5 4.4 with 82000 miles. I left my radio on for about 20 mins and the truck didn't start. I had to jump start it, a few minutes later the warning sign appeared " Trans Failsafe Prog. Does anybody know what's the problem? Note that I changed my battery last year, ( BMW battery)...Thank you. Last edited by lanass2; 06-13-2012 at 11:11 AM. |
Good day,
I did the same thing but I didn't get any problems when I put the charger on it... I think my battery voltage didn't drop far enough to cause issues with the electronics (they don't like anything less than 11.5V)... I would pull the battery terminal for 20 or so mins to reboot the computers... Be sure to turn your steering wheel, lock to lock to clear any sensor alarms... I have to do that on my 02... Good luck!! Cheers!! |
I will try that later...thanks for responding
transmission problem sa
kindly explain further please,mine is always giving problem weekly
let me know what to do if i have frequent trans program failure message even if the fluid level is okey
This sounds exactly like the problem I had. It is the alternator. I had mine replaced twice already and I have similar mileage. It will go into trans fail prog bec its a safemode when the voltage goes down. I had to drive back to dealer like that. Have them check your alternator.
| Bookmarks |
| Tags |
| battery alternator start, bmw x5, trans failsafe prog, transmission |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
