Old 11-26-2016, 07:21 AM
Eodiver Eodiver is offline
Mein Auto: F46 218da
coding star-stop on f11 xdrive
Hi from spain, we have tried today to code a f11 530d xdrive one to let the starstop function with last memory on so it didnt work unless driver wants.
we have tried with esys and carly and it has been impossible for us.
With carly didnt appear the option although it says it can be done in the web.
With esys, we are unable to find the file to code
has anyone done it and where is the file to code.
thanks in advance
Old 11-26-2016, 07:34 AM
Rob@BA's Avatar
Rob@BA Rob@BA is offline
Mein Auto: 5 Series. 3 Series.
- Auto Start-Stop function to start as last used
CAS => 3000 => TC_MSA_MEMORY => aktiv
2014 LCI
Already incorporated
- Auto Start-Stop OFF by default
CAS => 3000 => TC_MSA_DEFAULT_OFF => aktiv
Coding Specialist at Bimmer America LLC. E-Series and F-Series Remote Coding + NAV Updates. 10% off with promo code: "Rob"
Visit us at www.BimmerAmerica.com for the Complete BMW Enthusiast Source: News, Coding, Navigation Map Updates, Parts, Accessories, and Buying Guides.
Old 11-26-2016, 07:57 AM
thanks will take a look at it.
Old 11-26-2016, 12:09 PM
they dont appear in the F11
need more help
Old 11-27-2016, 09:04 AM
rogaa rogaa is offline
Mein Auto: F20 Estoril M-sport 2015
Your car probably has a build date of end 2011, in which the car did came with start/stop but without the driveselect buttons (eco pro/comfort/sport etc.) in this case you cannot code start/stop memory.
But just to be sure, CAS > TC_MSA_MEMORY
Old 11-27-2016, 11:12 AM
Hi , have checked and there is no TC_MSA_MEMORY
there is TC_MSA_SGR and TC_MSA_KSOPT
Is there any way of disconecting it forever, not just memorize last position?
Thanks in advance
Old 11-27-2016, 11:16 AM
Rob@BA's Avatar
Old 11-27-2016, 11:41 AM
Originally Posted by grzegorz914 View Post
Sorry was my bug, correct is:
TC_MSA_MEMORY ---- TC_RESERVED_BYTE3_BIT5
TC_MSA_DEFAULT_OFF ---- TC_RESERVED_BYTE3_BIT4
tested on F10 and working.
Originally Posted by TokenMaster View Post
This is correct. The latest CAFDs have RESERVED_BYTES_BITXXX all over. This lead me to believe that prior to trimming CAFDs, BMW tried to use names that makes no sense and figured out that trimming will actually do much more. Fortunately, these CAFDs are easy to spot.
I've just finished rebuilding the database and filtered these "noise" entries and will be releasing an update soon.
what about this?? WE do have those files in the f11.
Any Idea??
Old 11-27-2016, 01:19 PM
stealth98 stealth98 is offline
Mein Auto: BMW
Any Idea??
use esys with Tokenmaster, you'll find the setting. my F11 -2015 has the setting TC_MSA_MEMORY
best regards
Old 11-28-2016, 12:43 AM
AntDX316's Avatar
AntDX316 AntDX316 is offline
Mein Auto: 2013 750i xDrive
-CAS_
| CAS | 3000 TC | TC_MSA_DEFAULT_OFF | aktiv / Werte=01 | nicht_aktiv / Werte=00 | Turn Auto Start/Stop OFF by default
2013 750i xDrive
Old 11-28-2016, 02:15 AM
yushow5069 yushow5069 is offline
Mein Auto: BMW E39
FA add "K word" OMSA (Without engine start-stop function). FA code CAS
