Old 06-14-2012, 07:10 AM
Rainman519 Rainman519 is offline
Bavarian Garage
Mein Auto: 328i Coupe
Z4 Tire Swap
I've got a 2010 328i and a 2003 Z4 3.0, both w/sport packages and staggered set-up. Both cars have the exact same tire size (225-40R-18 front, and 255-35R-18 rear) and wear RFTs. The Z4 needs new tires. I want to take the opportunity to replace the tires on the 328 with non-RFTs (daily driver) and move the RFTs on the 328 to the Z4 thus putting new shoes on both cars for the price of one set of tires. My only concern is that the wheel styles on both cars are different. Any reason I shouldn't be able to make the swap since the tires sizes are the exact same? Thanks.
2010 328i Coupe w/Sport and Premium Pkg, Space Gray Met
2003 Z4 Roadster w/sport and premium Pkg, Sterling Gray
2010 Mercedes ML350
2012 Dodge Ram 1500
Old 06-14-2012, 02:09 PM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
The hub of the rim can have a different offset even though the rim itself is the same size. I'm not sure what the offset is on your 328. Worst case if it's a different offset you could run spacers. I'm running h&r spacers up front and I've been pretty happy with them so far
Old 06-15-2012, 03:14 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Are you swapping rims also?
If not, no problem.
If so, there are possible issues with hub diameter (should not be a problem) and offset, as has been pointed out.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 06-15-2012, 05:16 AM
GA Z4 GA Z4 is offline
Mein Auto: 2004 Z4
IIRC when I was shopping for autocross wheels I was killing myself trying to find wheels with a suitable offset for the Z4. I think the 328 offset won't work on the Z4 but the Z4 may work on the 328. The offset is stamped on the inside of the wheel usually with a E followed by a number, like E43, indicating 43 millimeters. Anyway if it was me I would swap them and see what worked, give them a spin and see if they rub, if it doesnt work, you'll have to dismount, remount and balance 8 tires. Let us know how it works out, good luck.
Old 06-15-2012, 09:03 AM
Bavarian Garage
Thanks guys. I guess I should have stipulated in the OP that I'm not planning to swap the wheels, only the tires. Since all my tires are exactly the same size, I'm assuming the tires from the 328 will fit the wheels of the Z4.
2010 Mercedes ML350
2012 Dodge Ram 1500
Old 06-15-2012, 10:46 AM
Mein Auto: 2004 Z4
Tire swap should be no problem, like you said they are the same size, just demount and remount and away you go.
