BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Retrofitting Lane Departure Warning
The referred car has SLI, High Beam Auto & HUD but does not have LDW. I believe the camera is still the same (as it is required by SLI). SLI works like a charm - almost 99% accurate on UK roads. Let me know if you want me to read settings from this car - just guide me into what you want done and I'll post the files. I am still a bit of newbie but happy to help out. My project is to get LDW working (as reading from your/ DreamCar/ others efforts on SLI) - I think it may be possible to get LDW working as they all share the same hardware camera. |
@gspannu thanks for showing interest.
For LDW you will also need the rear bumper sensors 66326857779 / 80. If possible please post the cafd files for KAFAS HU_CIC & KOMBI of this mentioned car. Only operation needed is read VCM, so nothing to worry about. Files should be stored in CAF folder.
F10 520d born 11.04.2011 Deep Sea Blue 205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1 |
@Dreamcar, @1stBimmer, @miotoo
I will be back home in about an hour. Will give it a go then and then read out the files and post here. I propose to do the following: 1. Clear out existing CAF folder (I have backups!) 2. Read the 3 files you have mentioned. 3. Post these files here. As a side question, @miotoo mentions I need the rear bumper sensors 66326857779 / 80 for LDW. Are these special sensors that come as part of a special pack or are these just normal PDC sensors. (I do not have Park Assist, I just have normal front & rear PDC). What are these sensors? |
I just got a MY2013 F25 with SLI but not LDW … … I didn’t want LDW, but its only now I see the user guide that I discover that LDW come with Forward Alert, which I would have taken the option for if only the sales associate had known or mentioned it. I am also left wondering if LDW and Forward Alert are coding option on the same hardware used for SPI. Of course, the steering wheel wont vibrate for LDW, and there is the small issue of the activation buttons on the dash, but none the less, if I could enable Forward Alert, I would be interested to see how this could be done … |
GSPannu,
Thanks for the files... I dont see any difference between these and Mobilieum's (I assuming this will be case for all EU countries). So enabling SLI in EU countries on cars with LDW should be a breeze. And regarding the question you posted for me in the other forum... We gotta check if we can activate the LDW with out the hard switch or if we can default the LDW to be "on" like HBA . Last edited by DreamCar; 06-11-2012 at 05:58 PM. |
@DreamCar, it's been mentioned that LDW needs special rear sensors ... What for?
Do you know if the Forward Warning uses anything other than the camera? On a side note, does the front camera have a video out anywhere? I was thinking of getting one of those loop recording dash cameras in case of an "event". Would be handy for the front facing camera to keep a loop of video prior to an accident or something. Failing that maybe it can be wired into a recording device...
F25 X3 xDrive 35d M Sport Alpine White, Black Nevada Leather, Speed limit info, TV, Prof. Nav & Speakers, HUD, M Sport steering wheel, Sport gearbox, BMW Apps, Internet, VDC, Comfort with Powered boot, Hi-speed synch, VSS, Top View, Electric tow-bar, Heated steering, Storage, DAB, Heated electric seats, Moonroof, Adaptive High beam assist Xenons, Servotronic, Performance control, etc. http://x3orevoque.co.uk |
Well thats what I think , I may be wrong. Last edited by DreamCar; 06-12-2012 at 01:19 AM. |
I thought the side sensors were used as well for blind spot, it doesn't seem they are since the cars aren't picked up until they are in range of the rear sensor... guess the side sensors are for parking assist..
2011 550i M-Sport 2011 Countryman S Bell 407 |
Now that you have the reference files from my car; and it seems that I may not need the rear sensors (hardware) - it should now be trying out 2 things: 1. Enabling LDW 2. Getting the LDW to be 'Always ON' - as there is no physical switch for the same. Any idea what changes I should try to get LDW working? As mentioned earlier; I have Speed Limit Info and Head Lamp Assist as factory standard. Can you advise which key functions/ values to try and modify? Much appreciated…. |
@gspanuu there are cafd files from @mobileum in the old thread http://www.bimmerfest.com/forums/sho...d.php?t=619819, his car is EU build and if I'm not mistaken has all 3 options LDW HBA SLI so comparing your files to his should be a good way forward for you.
I can't seem to find that post at the moment, but if no one gets to it, later I can post the files as I have them at home..
F10 520d born 11.04.2011 Deep Sea Blue 205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1 Last edited by miotoo; 06-12-2012 at 05:16 AM. |
Andy |
Hello Andy, when you say you tried, you mean the LDW worked & the missing action was only the steering vibration? Did you get the warning light in the kombi to show?
Andy |
Vibration generator is part 32336787451 for standard steering wheel. 74 Euro. Maybe new wiring is needed to pass the signal..
F10 520d born 11.04.2011 Deep Sea Blue 205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1 Last edited by miotoo; 06-12-2012 at 08:22 AM. |
mine right now is: 32336792421 but I would need 32336792423 and that's the expensive part. Check here: http://www.realoem.com/bmw/showparts...66&hg=32&fg=35 Andy |
@gspanuu these are the KOMBI, HU_CIC & KAFAS files from a EU car with SLI & LDW.
In the FDL editor, search for TLC entries which is the code for the Lane Depart Warning system.
3000, Lenkrad_Vibration Andy |
I am Ivory Pure (99.44%) sure that the Blind Spot Warning is only the side sensors. The pointing of the sensor allows it to pick up objects adjacent and behind it.
@miotoo @akiss @dreamcar
Great suggestions guys, I'm out until Sunday. Will give these a go on Sun or Mon evening and report back. Even if I get the warning to light up in dashboard, would be a good start; I can worry about the steering vibration later. Side question: How would I enable this permanently as I do not have a switch on/off button for LDW? @akiss: Since you have already achieved this... 1. do you happen to remember the exact settings changed/ documented anywhere? Saves me the hassle of going through the files line by line & comparing. 2. How did you manage without the physical switch? |
'12 F30 328i w/ A17, LCLY, ZLL/7S2, ZCW, ZDA, ZPK, ZPP, ZPS, ZTP, 205, 2VL, 302, 3DZ, 415, 417, 522, 524, 5AC, 5AP, 5DP, 615, 6AA, 6AB, 6NF, 6NL, 6NR, 6UH, 6VA, 6WA, 8S4, 8TH (yes, that's all lol) Retired: '09 E70 X5, '04 E46 M3 |
Yes, I do have a switch below my light switches. I have the HUD switch, but that's the only one...
Creating seperate thread for convinience.
#25
@DreamCar: Thanks for creating a separate thread. This could be a project on its own.
@akiss: Would much appreciate if you could locate the exact settings for LDW enabling specifically? I'll give this a go on Sunday/ Monday and then report back... |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
