E46 (1999 - 2006)
Old 06-14-2012, 09:00 AM
VT.330xi VT.330xi is offline
Mein Auto: 2002 BMW 330xi
Po171& po174!
Hello folks, I am new to this so bare with me. Yesterday at noon, car started running rough, ran fine in the morning. Scan tool came with PO171, PO174, too lean in bank 1and bank 2. Any idea's on this would be great. Thank you!
Old 06-14-2012, 09:26 AM
pconwell pconwell is offline
pconwell
Mein Auto: 2004 330 ci
First, it's P(zero)174, not P(oh)174.
I'm having the exact opposite problem, running rich in banks 1 & 2. Running lean means that either you are not getting enough fuel (fuel delivery problem) or you are getting too much air (air delivery problem).
Here are some basic, simple cheap things to check first:
* Check/replace your air filter
* Clean the MAF sensor
* Check/replace spark plugs (probably not the problem, but they are easy to check/replace)
* Run some 'fuel injector cleaner' through the car. (I've used sea foam and lucas before - they both seem pretty good).
Some less easy, less cheap things to look at:
* Replace the MAF sensor
* Replace fuel filter
* Replace fuel pump
* Clean/replace fuel injectors
* Replace oxygen sensors
So, that's just off the top of my head. Someone smarter than me can probably give you some better advice, but you can at least have a general idea where to start looking now.
Old 06-14-2012, 10:49 AM
9benua 9benua is offline
Mein Auto: 02 330i
Beside the engine check light turn on, What's the effect of ignoring this problem? My P0171 & P0174 triggers the engine light in my car every 3-4 weeks. Car is running fine, mpg still good, no rough idle.
Old 06-14-2012, 10:57 AM
pconwell
I'm not sure that I am qualified to answer that. My 'gut' response is that if it's not causing issues, you should be fine.
Old 06-14-2012, 11:09 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
Those codes are generally associated with a crack in you intake elbow between the MAF and the throttle body. Check for leaks first before you waste a lot of time and money chasing nebulous nonreated issues.
Name:	intake system.png
PT
___________________________________
Old 06-14-2012, 01:49 PM
rgk330i's Avatar
rgk330i rgk330i is offline
Mein Auto: 2013 335i M-Sport
The over lean condition is often caused by a vacuum leak (or more than one!), though a fuel delivery problem or a bad MAF sensor is possible too. The opportunities for a vacuum leak on the E46 are just about too numerous to mention. Prime candidates include the intake boots mentioned by P_T, the crankcase ventilation (oil separator) valve and associated hoses, the gasket where the DISA valve mounts to the intake manifold, the vacuum line that runs around the back of the engine and along the exhaust side of the valve cover, or even the simple little vacuum plug on the very back of the intake manifold against the firewall. I'm sure there are others too; those are just the ones I've had to deal with.
A shop will find them by injecting smoke into the intake system while the engine is stopped, and looking for where it leaks out. I find them by running the engine at idle and monitoring the short term fuel trim with an OBD-II reader while running a propane torch (unlit!) around the intake manifold and hoses looking for a sudden drop in the fuel trim.
2013 335i M-Sport, ED May 2013
Old 06-14-2012, 02:28 PM
Cleaned MAF& air filter, checked intake hose between MAF and throttlebody, reset computer and still came up with p0171& p0174.
Old 06-14-2012, 06:01 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
I had these codes when my DISA flap was broken. Did you pull the DISA to check it yet?
Old 06-14-2012, 07:16 PM
GLOK1132 GLOK1132 is offline
Mein Auto: 2002 325i
Could also be DISA flap or the seal is bad on the DISA. I have also heard that a Fuel pump going on it way out could also cause it, but don't quote me on that.
Old 06-14-2012, 07:49 PM
Bwood1 Bwood1 is offline
Mein Auto: 1999 528i, 2002 540i
I just had my 2001 325i in the shop and they diagnosed lean fuel trim (only under load). Said it was either the fuel filter or fuel pump. I had replaced the fuel filter about 13 months ago, but this is my daughters car and she runs it down to empty on a regular basis so we replaced the fuel filter and that has fixed it. No more SES light
Old 06-14-2012, 08:30 PM
rgk330i's Avatar
It makes sense that lean under load is likely to be fuel delivery, while lean at idle is likely to be an air leak - at higher rpm, any air leak is going to be a much smaller proportion of the total air intake.
Old 06-14-2012, 09:39 PM
pconwell
Here is a cool DIY vacuum leak tester if you feel like it might be a vacuum leak: http://forum.e46fanatics.com/showthread.php?t=445181
Old 06-15-2012, 08:39 AM
Just pulled Disa, it"s broken, pin fell out in my hand. Thanks every one for your help, hope this fixes it. Thank you for informing me of this, before I shot that pin thru my engine!
Old 12-26-2013, 09:17 PM
norcal325i norcal325i is offline
Mein Auto: 325i
When getting the 171 and or 174 codes I get a rough idle and or stalling when shifting from park to drive or reverse. I can clear the code and everything is perfect for a period of time. Then the light goes on again, rough idle. MAF is new, no visible cracks in boot... Next step DISA? Or smoke test?
Old 12-27-2013, 01:11 AM
SamxK SamxK is offline
Mein Auto: '01 330i
I had the exact same codes for a year. I examined my intake boots and DISA everything was okay. Changing the CCV did it for me. There was a torn oil line that was BARELY, and I mean barely visible after I had taken out my air filter and pushed all the wires and hoses aside. Check for any oil leaks around that area and around the engine cover. A small oil leak is enough to trigger that lean code (vacuum leak). Just my input for your problem. Hope it helps.
Old 12-27-2013, 05:44 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
The wiki has a good link for lean code troubleshooting: http://www.bimmerfest.com/forums/sho....php?p=8014505
You have an air leak or fuel pressure issue. Read the link on these codes. It's a good guide.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
