Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 06-15-2012, 07:15 AM
TDIwyse TDIwyse is offline
Mein Auto: 4 diesels
Intake charge air line question
Hypothetically, if someone wanted to remove the intake charge air line (#12 in diagram below) and reinstall, would they also need new seals (#13/14)?
http://www.realoem.com/bmw/showparts...88&hg=11&fg=40
And does anyone have experience with this removal/install procedure they can elaborate on?
2011 335d Sport Package/Cold Weather Package
2004 Ram Cummins with lots-o-mods
1990 YJ Repowered with modified Cummins B3.3T
Old 06-15-2012, 08:55 AM
d geek d geek is online now
diesel evangelist
Mein Auto: vw diesels + MB e300D-T
It would probably be best to replace the seals, but you could try to re-use and replace if you had any leak.
Old 06-15-2012, 01:53 PM
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
I would inspect them and see if they still are "fresh" enough i.e. not hardened and smashed down. It is not real complicated to measure the radial gap of the two parts being sealed. Measure larger diameter and smaller diameter being sealed at the o ring grove (if there is one). (OD-ID)/2 =radial gap to be sealed. Next measure with a caliper the o-ring thickness. Now is the complicated part. If this is a forced pressure line, the pressure on the o ring has to be higher than the pressur eit is sealing. The pressure on the oring is computed from how much deflection it undergoes to fit between the two diameters. If it's really a PITA to remove the line, spring for the $15 in seals and be done with it. Personally, i'd atleast inspect the old seals.
How old are the current seals?
Old 06-16-2012, 04:07 AM
Current seals are ~ 2 yrs old.
Found this thread that has some good info on the process.
http://www.bavarian-board.co.uk/foru...ne-replacement
Old 06-16-2012, 05:10 PM
After reading the DIY posting, i woudn't hesitate to change the seals. Do you have this oil leak issue too? I would think even if oil were not leaking that oil in that pipe going to the intercooler is BAD. Wouln't that foul up the ability to cool off the charge air as well as slow down air flow. I wonder if the oil is coming from the turbo in the first place?
best of luck.
Old 06-16-2012, 06:28 PM
No oil leak. Just curious in regards to future modifications . . .
Old 06-19-2012, 06:45 AM
Concentric190 Concentric190 is offline
Mein Auto: Turbo M3
I'll be trying this shortly.
///Andres
09 335d evolve tuned - 327whp / 490wtq -- 13.0@105
95 M3 Turbo - Built 3.0l s52, PTE74GTQ, AEM EMS & CDI
Old 06-19-2012, 07:34 PM
Nice. Hope you have time to share lessons learned.
Old 12-03-2012, 10:06 AM
dekesh dekesh is offline
Mein Auto: BMW X5 3.0SD M Sport
Sorry for bringing up an old thread but is this fix applicable to the X5 3.0SD MSport 2008/2009 model, as I too have a very similar situation with the red rubber hose covered in oil. Also I have noticed that it is a bit oily around the oil filler neck area. What could be causing this?
Changing the seals should be straight forward so not worried about doing that but why is the oil going through that pipe anyway. I may be wrong but should this pipe only have air going through it? Please can somebody clarify this for me.
Old 12-03-2012, 12:36 PM
62Lincoln's Avatar
62Lincoln 62Lincoln is offline
Mein Auto: 335d
Look through these threads:
http://www.e90post.com/forums/showth...red+boost+pipe
http://www.e90post.com/forums/showthread.php?t=595716
HTML code is Off
