E46 (1999 - 2006)
Old 06-15-2012, 06:21 PM
bradshaw bradshaw is offline
Mein Auto: BMW 325i 2002
Locked doors on BMW 325i cannot get in
I have a BMW 325i and the passanger door is locked as well as the 2 back doors. How do I get into my car? the central lock system isn't working. How can i bypass the general module and unlock my doors manually to get into the car. thanks.
Old 06-15-2012, 06:23 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
From the inside, pull twice on the door handle to unlock. That should do it.
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 06-15-2012, 06:29 PM
Burrogs's Avatar
Burrogs Burrogs is offline
Mein Auto: '04 330i ZHP 6-sp AW
Have you tried using the key?
Sent from my PC36100 using Bimmer App
2004 330i ZHP 6-spd, Alpine White/Black Cube/Alcantara, Koni FSDs w/ Eibach Prokit, no CDV, M3 RTAB with Vorschlag limiters, ULO-OEM Clears, Lightwerkz TFX upgrade, Blackout Kidneys, OEM M3 Strut Brace, OEM Bluetooth retrofit, DIY Clutch Stop, Sirius, Dr. VANOS kit, iPod integration
Old 06-15-2012, 10:15 PM
pconwell pconwell is offline
pconwell
Mein Auto: 2004 330 ci
If the door is in (what I will call) a 'hard lock' condition, pulling on the door handle will not unlock it. Test it out. Get in your car (but don't start it) and lock the car with the key fob. You cannot get out, the car is 'hard locked'. That's why there is a warning on the windshield to not lock the car with the key with anyone inside the vehicle.
I'm *guessing* that the OP is experiencing a 'hard lock' on the doors.
If not, the OP probably just needs to hit the unlock button twice (once for the driver door, twice for all the doors) or just needs to pull the handle twice from the inside.
The passenger and rear doors do not have a key hole (not sure what the technical term is there).
Old 06-16-2012, 03:52 AM
rgk330i's Avatar
rgk330i rgk330i is offline
Mein Auto: 2013 335i M-Sport
When you press the lock/unlock button inside the car, is there a soft "thunk" every other push? Does your driver's door lock from the key fob, but not unlock unless you use the key? If the answer to both of those is "yes", you probably have a bad lock relay in the GM5 module behind the glove box. See www.bmwgm5.com for a full description and a reasonable repair service.
The deadbolt or "hard lock" that pconwell refers to may unlock when you drive the car above the normal locking speed. At least, it at least sometimes did on my car -- I never did test it quite thoroughly enough to completely understand all the nuances. If that happens, then you are able to unlock with a double pull on the inside handles.
Until you get the relay fixed (assuming that's what it is) DO NOT lock your car from the key fob. Instead, manually push down the lock buttons. That way the deadlock will not set, and you'll still be able to unlock from the inside.
335i M-Sport, ED May 2013
325i, general module, locked door
