E46 (1999 - 2006)
Old 06-16-2012, 02:12 PM
JoshinAround JoshinAround is offline
Mein Auto: 2001 330i
Can only start car with wallet key! Pls help!
Hi guys,
I'm a proud first time owner of a BMW, a 01, 330i!
My only problem is that I can only start the car at first with the wallet key. The master key will only start the car if I immediately restart if after using the wallet key. Otherwise, the master key will work everything else except for the ignition.
I've looked everywhere for the answer...hoping you guys can help!
Thank you!
Old 07-10-2012, 04:23 PM
HarryR325i HarryR325i is offline
Mein Auto: 2002 BMW 325I
JoshinAround,
I had a problem with my keys during my first year of ownership where I wouldn't be able to start my car at all at times (even after an initial start up). Turns out the keys had to be "reset" by hitting the lock, unlock buttons in a specific sequence. I had to have the dealer do it. Sorry I'm not much help beyond this. Sounds like your keys may need to be reset. Good luck.
Old 07-10-2012, 07:02 PM
KenG KenG is offline
Mein Auto: 00' 323ci 5sp mt
Try tapping the metal key part on a hard surface, if it works then you will need a new key
Sent from my VM670 using Bimmer App
We never really grow up; we only learn how to act in public.
-unknown
I like Chile Verde Burritos
Old 12-29-2012, 09:17 AM
dmalen dmalen is offline
Mein Auto: 2000 BMW 323i
did you ever figure out the problem and how to fix it? I am having the exact same problem.
