E36 (1991 - 1999)
Old 06-18-2012, 12:56 PM
NeonNiteLite NeonNiteLite is offline
North Carolina Tar Heel
Mein Auto: '98 323iC, '98 GSX-R 600
Arrow Installed new A/C compressor, now the cruise control doesn't work?
I took my 323iC back to the dealership to have them replace the A/C compressor as promised (for free). On my way back home I noticed that the cruise control no longer worked anymore (it had always worked fine, including during my drive to the dealership). I called and asked the mechanic who worked on it if maybe he forgot to plug a harness back in or something, and he said definitely not. What could the problem be?
Old 06-18-2012, 07:47 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
not sure how an ac compressor would affect cruise...
things that affect the cruise would be brake/clutch switches, or a faulty servo motor or column switch.
are you drive by wire, or do you have a throttle cable??
df
Old 06-18-2012, 09:10 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
The mechanic may not have forgotten to plug something in, but there's a good chance he inadvertently knocked some electrical connection loose.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 06-19-2012, 04:54 AM
df
I have a 1998 323iC, which I believe has a throttle cable. When I left the dealership, I noticed that for about the first five minutes of driving the clutch made a slight clicking sound that I had never heard before. I'm not sure why it was doing that, but the sound went away quickly. When I got on the highway and tried to use cruise control, it didn't work and hasn't worked since.
Sounds like maybe I should take my panel off and check out the clutch switch, but I can't imagine why he would have messed around with my clutch or clutch switch for a compressor replacement.
Old 06-19-2012, 06:56 PM
well, it *is* an 98, and now, what, 3 chassis series old?? parts do happen to break.
again, i cannot see how replacing an ac compressor would affect cruise, so i would check the simple stuff first.
df
